IMHO - not worth the trouble.
Also, the HVX (and other video cams) are very tricky beasts, and are generally their own best meters. If you search, you'll find some reports that the HVX seems to have differing ISO equivalence depending on gamma setting and other camera variables. A light meter can be good for ballparking, but certainly use the camera itself as a final reference!
A waveform monitor is infinitely more helpful in lighting a greenscreen.
But for fine tuning, the light meter is the wrong tool for a video shoot; the waveform monitor and a properly calibrated production monitor are far more helpful.
? I put it in line mode, and I can tell immediately where it's uneven... I agree if you're viewing the full mode you would have a case, but in line mode it's simplicity, bliss, and perfection.I would disagree Barry. When viewing a waveform monitor pointed at a green screen, you certainly can see if the lighting is even, as this will manifest itself as a straight line on the waveform, however, if any part of the screen is uneven, the waveform monitor won't show you where its uneven beyond a vague generality like screen left or screen right. Thats the key reason why people light green screens with spot meters.
I'm a fan of light meters, I have a Sekonic 508C, I'm a big fan of the spotmeter in the HVX and HPX, etc. With that said, I think I've seen a lightmeter used on a professional video shoot maybe exactly once in the last 8 years, used to fine-tune anything.But fine tuning is something you usually do with a spot meter, even if your working with video, actually even more so with video. Your margin for error isn't too forgiving.
With video, that's exactly the case. A calibrated production monitor will show you exactly what you're getting.I think a lot of people who have grown up around video approach it with too much of a what you see is what you get attitude, and its simply not the case
The Red One's not a video camera though. It's its own, unique, raw digital thing; it doesn't conform to video standards., and Red One is proving that quite bluntly.
For a raw signal like an Andromeda or a Red, or film, that's true. For any video camera that's totally not true and not accurate. What the monitor is showing is the only thing that matters.If you know what the cameras range is and ISO rate based off clipping, you simply won't have to worry about what that monitor is showing.
Agreed.I also find that spot metering really forces people to develop a more critical eye for lighting, which is a good thing.
Well, we should agree to disagree. Lighting a set is one thing, but if the video processing is redistributing your values around and the knee and toe are doing odd things to your video, you *have* to compensate for what the camera is doing. You can't force the camera to just like your lighting setup, you have to make the lighting comply to the camera's processing. I mean, obviously you adjust the camera settings as best you can, but when working with video the only rational approach (to me) is results-based. Whatever you have to modify at the source, well, you do what you gotta do so that the end result looks good. And the only way to know the end result is to monitor the results, and adjust the lighting appropriately to compensate.Waveforms and vector scopes have there places, but I mainly see them as useful ways to monitor a signal which is what they are meant for, but not lighting a set.
The gamma curves in video cameras are going to push your midtones up, or down, or crush the darks, or extend them, or do any manner of manipulation to your signal. There is no flat linear response in a normal video camera. If there was, then using the light meter would be a simple approach, but there isn't.
can you give us only an anticipation of your tutorial.??
for example about how to set and base a spot meter off clipping??
"Not worth the trouble."
