I have a Glidecam 2000. The max suggested weight is 6lbs.
I’m going to get a Sony FS 700 when it comes out. I’ve estimated the weight of my Sony FS 700 with lens, ext. monitor, etc…. to be around 7 lbs, about 1 lbs over the 6 lbs limit.
Do you think I can get away with using the Glidecam 2000 (and steadycams in general) at 1 lbs over the suggested weight limit? I can extend the base if needed to further balance the rig, or add additional weights.
Basically, even if it’s over the suggested weight limit by X- amount, as long as you can balance the steadycam, it will work properly. Is that a correct assumption?
