Rory Martinez
For sale is a used Glidecam X-22 with accessories. We purchased this item for a job a few years ago, but it has received minimal use and is becoming less and less useful to us in our productions. The unique thing about this Glidecam is that we’ve had a 10 pound weight plate manufactured which allows the camera to be used with a much larger variety of cameras, from DSLR’s to Arri Alexas. The sled flies with just the weight plate mounted, which is a great start when setting up. We’ve achieved great results with this piece of kit and it really is an affordable, great price when placed against other prosumer camera stabilization systems
**ASKING £4500 ONO**
GLIDECAM X-22
The Glidecam X22AB Stabilizer is a professional camera stabilization system designed for film or video cameras weighing from 10-25 pounds. The system allows the operator to walk, run, ascend or descend stairs, shoot from moving vehicles and travel over uneven terrain without camera instability. This package includes the vest, arm, monitor, sled, and docking bracket.
Glidecam X22 Sled
A full featured, precision Support Sled designed to carry film and video cameras weighing from 10 to 25 pounds. The Glidecam X22 Sled incorporates 12-volt integrated wiring.
Vest and Arm
The vest and arm distribute the weight of the system to the torso. This allows for longer shooting times with less fatigue.
SPECIFICATIONS
Construction - Aluminum and stainless steel
Load Capacity - 25.0 lbs (11.3kg)
Vest - X-22 Support Vest
Arm - X-22 Dual-Articulating Support Arm
Head Assembly/Top Stage - Drop-in dovetail head design requires no tools to mount camera
Quick Release - No
Docking Bracket - Yes
Dovetail Plate - Yes
Gimbal - Three axis
Dynamic Spin - Yes, 360°
Post - 5" and 10" included
Battery Mount - V-Lock
MARSHALL V-LCD70XP-HDMI-CM
The Marshall V-LCD70XP-HDMI-CM is a durable, lightweight 7" LCD field monitor designed for use on both camcorders and video DSLRs. Equipped with a scratch-resistant, high resolution 1.2MP TFT screen that provides exceptional clarity and brightness, this HD monitor brings a new level of ease to general framing and focus-checking. Otherwise identical to the earlier '70P' monitor, the '70XP' adds several convenient new features: manual gamma adjustment via the menu, image flip, adjustable on-screen markers, and the ability to place 1/4-20 threads on any side of the monitor for more flexible mounting.
Along with its Canon mount, the V-LCD70XP-HDMI-CM comes equipped with component, composite, and HDMI inputs plus a variety of screen formats, markers and user-configurable function buttons.
Marshall's Professional Details
Marshall Electronics builds their LCDs for professional applications and convenient, user-friendly operation. In addition to its high quality image, the display will accept a wide variety of input signals.
Completely Digital
The V-LCD-70XP-HDMI-CM features a completely digital TFT high resolution LCD screen with 1.2 million pixels, 4-pin XLR power jack, and optical grade polycarbonate screen protection. Analog signals are digitized using advanced 10-bit processing with 4x oversampling and an adaptive 5-line comb filter.
Automatic NTSC/PAL Recognition
The V-LCD70XP-HDMI-CM accepts both NTSC and PAL standard signals. Conveniently, the monitor automatically detects which standard it is being fed without having to push a button, flip a switch or access a menu option.
False Color & Peaking Filters
A sophisticated color and peaking filter system will let you run tests and do various adjustments in order to achieve very accurate color and sharpness settings according to a particular lighting and scene situation. Once these settings are locked in, you can be sure that what you see on the monitor is exactly what the camera is capturing.
False Color Filter
The False Color filter is used to aid in the setting of camera exposure. As the camera Iris is adjusted, elements of the image will change color based on the luminance or brightness values. This enables proper exposure to be achieved without the use of costly, complicated external test equipment.
Peaking Filter
The Peaking Filter is used to aid the camera operator in obtaining the sharpest possible picture. When activated, all color will be removed from the display and a black-and-white image will remain. The internal processor will display RED color on the screen where sharp edges appear.
Scratch Resistant Screen
As almost all professionals know, the field can be a rough place. The monitor's LCD incorporates a scratch-resistant protective screen, so you no longer have to worry about a stray branch leaving its mark across your picture-perfect image.
15:9, 16:9, 4:3, pixel-to-pixel modes
RGB gain and bias control
SPECIFICATIONS
Application - Field Monitor
LCD Size - 7"
Video System - NTSC, PAL
Picture Elements - 800 x 480, 18-Bit Colour
Input and Output Connectors - Composite Video: BNC (x1 Input, x1 Output)
Component Video - BNC (x1 Input, x1 Output)
HDMI - x1 Input
Picture Controls - Brightness, Color, Tint, Contrast, Menu, F1-F4
Remote Control - No
Power Requirements - V-Lock Battery or 12V DC
Power Supply - XLR 100-240VAC, 50/60Hz
Power Consumption - 12W
Dimensions (WxHxD) - 7.03 x 5.7 x 2.17 (17.9 x 14.5 x 5.5 cm)
Weight - 1.9 lbs (0.86kg)
PAG 95 BATTERY V-LOCK CONNECTION
The PAG L95 9360 is a 14.8 VDC 95 Wh Lithium Ion Battery; high voltage and light weight construction. This model offers V-Lock connectivity.
14.8 Volts
The 14.8V 6.5Ah pack has a capacity of 95 watt-hours and yet weighs only 745g. The result is increased run-time for both a camcorder and a camera light up to 35W.
SPECIFICATIONS
Chemistry - Lithium Ion
Output Voltage - 14.8 VDC
Connection - V-Lock Connector
Capacity - 95 Wh
Weight - 1.64 lbs / 745 grams
Dimensions (WxHxD) - 3.4 x 1.65 x 5.1" / 8.6 x 4.2 x 13.0cm
PAG 9613V Freelancer Charger - 2x V-Lock Connectors, 12-14.8 VDC
The 9613V PAG Freelancer is an ultra-compact, economical, 2-channel charger. It has a tough but lightweight molded construction that makes it an ideal travel or back-up charger. This charger charges PAG batteries featuring V-Lock connectors.
Recovery Charge
The Freelancer incorporates a Recovery Charge program for PAG Li-Ion batteries that will automatically recover the battery when the output has been shut down by the internal protection circuit.
Extended Battery Life
The Freelancer features PAG ACS software which will extend the cycle life of your batteries beyond anything that can be achieved using other systems.
User Interface
The charger's user interface features a comprehensive LED indication of battery and charger status. The charger is fully automatic in operation and constantly monitors every process.
Sequential All Chemistry
The all-chemistry Freelancer incorporates two full-sized V-Lock connectors and will sequentially charge V-Lock batteries.
Worldwide Voltage
A built-in high frequency switch-mode power supply adjusts automatically to accept worldwide power voltages.
SPECIFICATIONS
Battery Bays - 2 V-Lock / All Chemistry
Type of Charging - Sequential
Diagnostics - Auto Charge Rate Selection/ State of Charge / Analytic Charge/Discharge
Connections/Interface - V-Lock (x 2)
Power Requirements - 100-240 Volts AC, 50 or 60 Hz
Dimensions (WxDxH) - 4.4 x 2 x 5.25" / 11.2 x 2 x 13.3cm
Weight - 1.0 lbs / 434 grams
GLIDECAM X-22
Glidecam X22 Sled
Vest and Arm
SPECIFICATIONS
Quick Release - No
Gimbal - Three axis
Completely Digital
False Color Filter
Peaking Filter
SPECIFICATIONS
LCD Size - 7"
HDMI - x1 Input
Remote Control - No
14.8 Volts
SPECIFICATIONS
Capacity - 95 Wh
Recovery Charge
User Interface
Worldwide Voltage
SPECIFICATIONS
