woodcarver
I'm wondering if you format your SSD to work for direct recording from a GH6 can you still use the SSD to store other files or does it have to be dedicated to recording GH6 video?
I Recording directly to an SSD instead of an SD card would eliminate a step for them and an expense for the department.
Shooting on ordinary SD cards is just plain easier, too. Why muck around with an SSD onboard the camera if you don't have to?
What about backups and archiving? They only have ONE copy?
And what if someone starts their edit, but then needs to go out for another shoot, are they going to take that SSD out into the field again? This seems like a really dumb idea and sets a very bad example for the students.
Editing direclty from the media you use for recording is just plain dumb. Cards and drives are so cheap these days there is no excuse not to follow proper protocols. And that is especially important for students to learn.
I don't know if this will work for your students, but the GH6 will record onto USB-C thumb drives, treating them just like an SSD. Here's a video I posted on YouTube about using a $20 256GB thumb drive on the GH6 -- and I have since tested that thumb drive by recording 648Mbps ProRes, and it worked fine:...but for many students an $80 SSD is a significant purchase and they're just trying to get through the semester so multiple drives are a no go. And anything that simplifies the workflow for non-professionally oriented students is worth considering.
I'm just mentioning all this as a way of saying that you might want think twice about calling an idea "just plain dumb" especially if you don't know the full context.
There are formats that the GH6 has that can not be recorded to an SD card. For example, none of the ProRes formats can be recorded on an SD card -- the GH6 will not permit it. You can record ProRes only to a CFExpress card or an SSD. Since CFExpress cards are much more expensive than similar-sized SSDs, an SSD is your low-cost alternative to recording in ProRes on the GH6.
FWIW, I have only recorded on the GH6 in ProRes to test the function, but it was a smooth editing experience afterward.
That's a really useful video, Bob, thanks!
