DeadEyesSmiling
Hey, y'all. Any help on this would be most appreciated, my headspace is maxed out.
I'm wanting to know if the Rokinon Cine DS 10mm with the Ultra 0.71x Speedbooster will work with the DCI aspect on the GH5S. The information I'm finding online is contradictory at best.
All of the info I've found about the GH5S sensor says it requires a lens with at least a 30.5mm image circle (LINK).
I've found information that says the 10mm has an image circle of 28.37mm (LINK), so that definitely shouldn't work. But I've also found info (LINK) that says the 10mm will work on the Dragon 6K sensor, which has an image circle requirement of 32.2 - 34.55mm (LINK).
But then (THIS) YouTube video shows the 10mm doesn't work with the 6K FF, but will work with the 5K crop, which has an image circle requirement of 28.9mm.
So, I'm confused. Does anyone have any additional insight or even this configuration that could test for me?
-DES
-DES
