I just noticed when I have a HDMI cable attached to my GH5 it does not ask for the focal setting for the IBIS on startup like it usually does when you boot up with a non stabilized non-electronic lens (Voigtlander 25mm). It actually flashes up on the screen for a second but then goes away not giving enough time to set it. Not sure if this is considered a bug, I can still go in and set it with the stabilizer function I have set to FN3 but I like having the reminder to set it when I boot up in case I changed lenses and need to reset it. I'm running firmware version 2.1.
