GH4 GH4 with FCP X why is the file PAL in 4k?
tee
. I am using with my new GH4 in 24p (system frequency is set to 24p) and when I record to 4k and try to import the file into FCPX, the Codecs column for the file is PAL. I do not understand why this is, or really if it is meaningful. Thanks for any help with this.
you need to find in the camera settings where it says NTSC 59.-- hz (-- are whatever the last 2 numbers are, can't remember). also make sure you FCPX import settings are all correct.
