GH4 Gh4 Newbie needs help with shooting concert footage
If you are an 'official' member of the crew, then the board sound is not a problem. If you are unofficial, then you are potentially in a tricky place? Permissions and rights etc. Shooting live amplified sound with a shotgun is problematic in the extreme. If you are close in, as you pan around, your sound will include what is coming out of monitors, side fills, the subs, the ground stacked or flown line arrays - and many of these are very directional, so the sound balance and quality will be very weird and constantly changing. If you have to shoot from further away with a long lens, then a cheap lightweight tripod and head is going to be wobblytown. If you are more than 20m from the action, with the lens at it's narrowest end, then annoying and tilting will be very jerky. Closer in, perhaps stage side, will look good and not be so wobbly as you'll be on your lenses wider range. The sound, in my view will be more a problem than the picture. At the very least, a portable recorder aimed at the PA and not moved will be better. I dot lots of go pros around stages for interesting cutaways, and the sound is ALWAYS awful - not quality, but what you can hear. One last week had great pictures, but all you could hear was a very loud guitar - everything else was almost missing.
No. As Greg_E noted, you need to work with the sound guy and get a full mix (not just the mics/PA) from the board, and then sync in post. (And FWIW, I use a TASCAM DR100 Mk II and Zoom H6.)
I shoot with a (hacked) GH1 and GH2, Olympus E-M5 II, Canon T4i/650D and 70D.
And keep in mind that the FZ1000 is 16X zoom (max 400mm equiv.) at f4 while the FZ200 is 24X (max 600mm equiv.) at f2.8
But of course the FZ1000 sensor is much more low-light capable 1". I'd bet there's at least twice the 1 EV lens speed difference in hi-ISO noise.
Pete
True. But there's also the focal length difference to consider. And while I wouldn't be comfortable shooting video in uncontrolled circumstances at even the FZ1000's 400mm (equiv.), it seems like the OP might be. Or not. Maybe I'm wrong.
Good point, as he was shooting the FZ19 in his P&S video, which must have been very well lit, as in 1080p mode the reach is 560mm EFL - at f/6.3! And he got in really tight. I was just checking out the new FZ300 specs, which uses same sensor and fixed 2.8 zoom, but adds 4K at 100mbps! The new 5-axis IBIS won't fly with 4K, though, leaving the OIS. Panny has merged the two IS systems somehow for FHD and lower res video.
