keylight
Panasonic has them on their site, so these are the real deal Few nice surprises, few disappointments.... I've highlighted what I think people are most interested in. Let me know if I missed something that should be highlighted and I'll fix that! And I've attached the System Chart too.
Recording Media
Image Sensor Size
Lens Mount
IMAGE SENSOR
Total Pixels
Camera Effective Pixels
Color Filter
Dust Reduction System
RECORDING SYSTEM
Motion Image:
Aspect Ratio
Image Quality
Color Space
File Size (Pixels)
MP4*2
AVCHD Progressive*2
Continuous Recordable Time (Motion Image)*4
Actual Recordable Time(Motion Image)*4
Flicker Reduction
Time Code (Motion Image)(Except MP4)
Wi-Fi
VIEWFINDER
Field of View
Magnification
Eye Point
Diopter Adjustment
Auto Eye Sensor
FOCUS
Focus Mode
AF Mode
AF Assist Lamp
AF Lock
Others
EXPOSURE CONTROL
Light Metering Mode
Metering Range
Exposure Mode
ISO Sensitivity (Standard Output Sensitivity)
Exposure Compensation
AE Lock
AE Bracket
WHITE BALANCE
White Balance Adjustment
Color Temperature Setting
White Balance Bracket
SHUTTER
Shutter Speed
Self Timer
Remote Control
SCENE GUIDE
Motion Image -Clear Portrait / Silky Skin / Backlit Softness / Clear in Backlight / Relaxing Tone / Sweet Child's Face / Distinct Scenery / Bright Blue Sky / Romantic Sunset Glow / Vivid Sunset Glow / Clear Nightscape / Cool Night Sky / Warm Glowing Nightscape / Artistic Nightscape / Clear Night Portrait / Appetizing Food / Cute Dessert / Freeze Animal Motion / Clear Sports Shot / Monochrome
BURST SHOOTING
FLASH
MONITOR
Monitor Size
Pixels
Field of View
Monitor Adjustment
LIVE VIEW
Extra Tele Conversion
CREATIVE CONTROL
CREATIVE VIDEO MODE
Slow and Fast Motion
PLAYBACK
INTERFACE
Audio Video Output - Monaural Type, NTSC / PAL, NTSC only for North America * Check the website of the Panasonic sales company in your country or region for details on the products that are available in your market.
Remote Input - 2.5mm for remote
External Microphone Input - 3.5mm for external microphone
Headphone Output - 3.5mm for headphone
Microphone - Stereo, Wind-cut: OFF / Low / Standard / High / Auto
OTHER
LANGUAGE
POWER
DIMENSIONS / WEIGHT
OPERATING ENVIRONMENT
Operating Humidity -10%RH to 80%RH
STANDARD ACCESSORIES
OPTIONAL ACCESSORIES
Recording Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card (Compatible with UHS-I standard SDHC / SDXC Memory Cards)
Image Sensor Size
17.3 x 13.0 mm (in 4:3 aspect ratio)
Lens Mount
Micro Four Thirds mount
IMAGE SENSOR
Live MOS Sensor
Total Pixels
17.20 Megapixels
16.05 Megapixels
Color Filter
Primary color filter
Supersonic wave filter
RECORDING SYSTEM
Recording File Format
Still Image:
JPEG (DCF, Exif 2.3), RAW
MPO (When attaching 3D lens in Micro Four Thirds System standard)
Motion Image:
AVCHD Ver 2.0 compliant (AVCHD Progressive),
MPEG4-AVC (H.264). (MOV, MP4)
Aspect Ratio
4:3, 3:2, 16:9, 1:1
Image Quality
RAW, RAW+Fine, RAW+Standard, Fine, Standard
MPO+Fine, MPO+Standard (When attaching 3D lens in Micro Four Thirds System standard)
Color Space
sRGB, Adobe RGB
File Size (Pixels)
Still Image
[4:3] 4,608 x 3,456 (L), 3,264 x 2,448 (M), 2,336 x 1,752 (S), 1,824 x 1,368 (When attaching 3D lens in Micro Four Thirds System standard)
[3:2] 4,608 x 3,072 (L), 3,264 x 2,176 (M), 2,336 x 1,560 (S), 1,824 x 1,216 (When attaching 3D lens in Micro Four Thirds System standard)
[16:9] 4,608 x 2,592 (L), 3,264 x 1,840 (M), 1,920 x 1,080 (S), 1,824 x 1,024 (When attaching 3D lens in Micro Four Thirds System standard)
[1:1] 3,456 x 3,456 (L), 2,448 x 2,448 (M), 1,744 x 1,744 (S), 1,712 x 1,712 (When attaching 3D lens in Micro Four Thirds System standard)
Motion Image
MOV*1
NTSC
[Full HD] 1,920 x 1,080, 30p (sensor output is 30p, 72Mbps (ALL-Intra))
[Full HD] 1,920 x 1,080, 24p (sensor output is 24p, 72Mbps (ALL-Intra))
[HD] 1,280 x 720, 60p (sensor output is 60p, 72Mbps (ALL-Intra))
[Full HD] 1,920 x 1,080, 60p (sensor output is 60p, 50Mbps (IPB))
[Full HD] 1,920 x 1,080, 30p (sensor output is 30p, 50Mbps (IPB))
[Full HD] 1,920 x 1,080, 24p (sensor output is 24p, 50Mbps (IPB))
PAL*3
[Full HD] 1,920 x 1,080, 25p (sensor output is 25p, 72Mbps (ALL-Intra))
[HD] 1,280 x 720, 50p (sensor output is 50p, 72Mbps (ALL-Intra))
[Full HD] 1,920 x 1,080, 50p (sensor output is 50p, 50Mbps (IPB))
[Full HD] 1,920 x 1,080, 25p (sensor output is 25p, 50Mbps (IPB))
MP4*2
NTSC
[Full HD] 1,920 x 1,080, 30fps (sensor output is 30p, 20Mbps)
[HD] 1,280 x 720, 30fps (sensor output is 30p, 10Mbps)
[VGA] 640 x 480, 30fps (sensor output is 30p, 4Mbps)
PAL*3
[Full HD] 1,920 x 1,080, 25fps (sensor output is 25p, 20Mbps)
[HD] 1,280 x 720, 25fps (sensor output is 25p, 10Mbps)
[VGA] 640 x 480, 25fps (sensor output is 25p, 4Mbps)
AVCHD Progressive*2
NTSC
[Full HD] 1,920 x 1,080, 60p (sensor output is 60p, 28Mbps)
PAL*3
[Full HD] 1,920 x 1,080, 50p (sensor output is 50p, 28Mbps)
AVCHD*2
NTSC
[Full HD] 1,920 x 1,080, 24p (sensor output is 24p, 24Mbps)
[Full HD] 1,920 x 1,080, 60i (sensor output is 30p, 24Mbps)
[Full HD] 1,920 x 1,080, 60i (sensor output is 60p, 17Mbps)
PAL*3
[Full HD] 1,920 x 1,080, 50i (sensor output is 25p, 24Mbps)
[Full HD] 1,920 x 1,080, 50i (sensor output is 50p, 17Mbps)
AVCHD: Approx. 240 min with H-HS12035 / Approx. 220 min with H-VS014140
AVCHD: Approx. 120 min with H-HS12035 / Approx. 110 min with H-VS014140
Flicker Reduction
[1/50] [1/60] [1/100] [1/120] / OFF
ON / OFF, Count Up: Rec Run / Free Run selectable, Time Code Mode: Drop Frame / Non-drop Frame selectable (NTSC only)
Wi-Fi
IEEE 802.11b/g/n, 2412 MHz - 2462 MHz (11 ch), Wi-Fi / WPA / WPA2, Infrastructure mode
VIEWFINDER
Type
OLED Live View Finder (1,744K dots equivalent)
Field of View
Approx. 100%
Magnification
Approx. 1.34x / 0.67x (35 mm camera equivalent)
Eye Point
Approx. 21 mm from eyepiece lens
Diopter Adjustment
-4.0 - +4.0 (dpt)
Auto Eye Sensor
Yes
FOCUS
Type
Contrast AF system
Focus Mode
AFS (Single) / AFF (Flexible) / AFC (Continuous) / MF
AF Mode
Face detection / AF Tracking / 23-area-focusing / 1-area-focusing / Pinpoint (Full area touch is available)
AF Assist Lamp
YES (ON / OFF)
AF Lock
Yes (AF/AE LOCK button)
Others
Quick AF, Continuous AF (during motion image recording), AF+MF, Eye Sensor AF, Touch AF, Touch Pad AF, Touch shutter, Touch MF Assist, Shutter AF, Half Press Release
EXPOSURE CONTROL
Light Metering System
144-zone multi-pattern sensing system
Light Metering Mode
Intelligent Multiple / Center Weighted / Spot
Metering Range
EV 0 - 18 (F2.0 lens, ISO100 equivalent)
Exposure Mode
Program AE / Aperture Priority AE / Shutter Priority AE / Manual
Auto / Intelligent ISO / 200 / 400 / 800 / 1600 / 3200 / 6400 / 12800 (Changeable to 1/3, 1 EV step)
(Extended ISO125 - less under 200, ISO more over 12800 - 25600 available) (Up to ISO3200 in Auto)
1/3 EV Step, ±5 EV (±3 EV for motion image)
AE Lock
AF/AE LOCK button
AE Bracket
3, 5, 7 frames, in 1/3, 2/3 or 1 EV Step, single / burst
WHITE BALANCE
White Balance
Auto / Daylight / Cloudy / Shade / Incandescent / Flash / White Set 1, 2 / Color temperature setting
Blue/amber bias, Magenta/green bias
2,500 K - 10,000 K in 100 K
3 exposures in blue/amber axis or in magenta/green axis
SHUTTER
Type
Focal-plane shutter
Shutter Speed
Still Images: 1/4,000 - 60 and Bulb
Motion Images: 1/16,000 - 1/30 (NTSC), 1/16,000 - 1/25 (PAL)
Self Timer
10 sec, 3 images after 10 sec, 2 sec
Remote Control
Remote control with Bulb function by DMW-RSL1 (Optional)
SCENE GUIDE
Still Image -Clear Portrait / Silky Skin / Backlit Softness / Clear in Backlight / Relaxing Tone / Sweet Child's Face / Distinct Scenery / Bright Blue Sky / Romantic Sunset Glow / Vivid Sunset Glow / Glistening Water / Clear Nightscape / Cool Night Sky / Warm Glowing Nightscape / Artistic Nightscape / Glittering Illuminations / Clear Night Portrait / Soft Image of a Flower / Appetizing Food / Cute Dessert / Freeze Animal Motion / Clear Sports Shot / Monochrome
BURST SHOOTING
Burst Speed - SH: 20 frames/sec (4M), H: 6 frames/sec, M: 4 frames/sec (with Live View), L: 2 frames/sec (with Live View)
FLASH
Built-in Flash
TTL Built-in-Flash, GN12.0 equivalent (ISO100 · m), GN17.0 (ISO200 · m), Built-in Pop-up (Reference)
Flash Mode
Auto, Auto / Red-eye Reduction (when iA, iA+), Forced ON, Forced ON / Red-eye Reduction, Slow Sync., Slow Sync. / Red-eye Reduction
Synchronization Speed
Less than 1/160 second
Flash Output Adjustment
1/3 EV Step ±3 EV
Flash Synchronization
1st Curtain Sync., 2nd Curtain Sync.
Synchronization for Flash Dimming and Exposure Compensation
Yes (ON / OFF)
Flash Sync Socket
Yes
Flash Mode
1/3 EV Step ±3 EV
Yes (ON / OFF)
Flash Sync Socket
Yes
MONITOR
Type
OLED monitor with static touch control
Monitor Size
Free-angle 3.0 inch (7.5 cm) / 3:2 Aspect / Wide-viewing angle
Pixels
614K dots
Field of View
Approx. 100%
Monitor Adjustment
Brightness (7 levels), Color (7 levels), Red-Green (11 levels), Blue-Yellow (11 levels)
LIVE VIEW
Digital Zoom
2x, 4x
Still Image: Max. 2x (Not effective with L size recording. Magnification ratio depends on the recording pixels and aspect ratio.)
Motion Image: 2.4x, 3.6x, 4.8x (Magnification ratio depends on the recording quality and aspect ratio.)
Other Functions - Guide Lines (3 patterns) & Real-time Histogram
CREATIVE CONTROL
Still Image - Expressive / Retro / High Key / Low Key / Sepia / Dynamic Monochrome / Impressive Art / High Dynamic / Cross Process / Toy Effect / Miniature Effect / Soft Focus / Star Filter / One Point Color
Motion Image - Expressive / Retro / High Key / Low Key / Sepia / Dynamic Monochrome / Impressive Art / High Dynamic / Cross Process / Toy Effect / Miniature Effect / One Point Color
CREATIVE VIDEO MODE
Exposure Mode
Program AE / Aperture-Priority / Sutter-Priority / Manual Exposure
40% / 48% / 80% (Records 0.4 times, 0.48 times, 0.8 times slower)
160% / 200% / 300% (Records 1.6 times, 2.0 times, 3.0 times faster)
(1,920 x 1,080, 24p, 24Mbps in MOV, MP4, AVCHD)
PLAYBACK
Playback Mode - Normal playback, 30-thumbnail display, 12-thumbnail display, Calendar display, Zoomed playback (Max. 16x), Slideshow (All / Picture Only / Video Only / 3D / Category Selection / Favorite, duration & effect is selectable), Playback Mode (Normal / Picture / Video / 3D Play / Category / Favorite), Title Edit, Text Stamp, Video Divide, Resize, Cropping, Rotate, Favorite, DPOF Print Set, Protect, Face Recognition Edit
INTERFACE
USB - USB 2.0 High Speed
HDMI - mini HDMI TypeC
Video: Auto / 1080p / 1080i / 720p / 480p (576p in PAL system)
Audio: Dolby® Digital
Speaker - Monaural
OTHER
Image Protection - Single / Multi, Cancel
Erase - Single / Multi / All / Except Favorite
Level Gauge - Yes
Vertical Shooting Detection - Yes
Photo Style (Still Image and Motion Image) - Standard / Vivid / Natural / Monochrome / Scenery / Portrait / Custom
Print - Direct Print & PictBridge compatible
LANGUAGE
OSD Language - English, German, French, Italian, Spanish, Polish, Czech, Hungarian, Russian, Chinese (Traditional), Chinese (Simplified), Dutch, Thai, Korean, Turkish, Portuguese, Arabic, Persian, Japanese, Swedish, Danish, Finnish, Greek, Vietnamese Check the website of Panasonic sales company in your country / region or ask customer support for details of the OSD language available on the products sold in your country / region.
POWER
Battery - Li-ion Battery Pack (7.2V, 1,860mAh) (Included)
Battery Charger
Battery Life (CIPA Standard)*5
Battery Charger
Approx. 540 images with H-HS12035
Approx. 500 images with H-VS014140
DIMENSIONS / WEIGHT
Dimensions (W x H x D)
132.9 x 93.4 x 82.0 mm / 5.23 x 3.68 x 3.23 inch (excluding protrusions)
Weight
Approx. 550 g / 19.40 oz (SD card, Battery, Body)
Approx. 470 g / 16.58 oz (Body only)
Approx. 855 g / 30.16 oz (SD card, Battery, H-HS12035 lens included)
Approx. 1,010 g / 35.62 oz (SD card, Battery, H-VS014140 lens included)
Operating Temperature -0 °C to 40 °C (32 °F to 104 °F)
Software
PHOTOfunSTUDIO 8.5 PE,
SILKYPIX® Developer Studio 3.1 SE,
LoiLoScope (trial version)
Standard Accessories
DMC-GH3 Kit - Body, Battery Charger (included AC cable), Battery Pack, Body Cap, USB Connection Cable, Shoulder Strap, CD-ROM
DMC-GH3A Lens Kit - Body, LUMIX G X VARIO 12-35mm / F2.8 ASPH. / POWER O.I.S. (H-HS12035), Lens Cap, Lens Hood, Lens Rear Cap, Battery Charger (included AC cable), Battery Pack, Body Cap, USB Connection Cable, Shoulder Strap, CD-ROM
DMC-GH3H Lens Kit - Body, LUMIX G VARIO HD 14-140mm / F4.0-5.8 ASPH. / MEGA O.I.S. (H-VS014140), Lens Cap, Lens Hood, Lens Rear Cap, Battery Charger (included AC cable), Battery Pack, Body Cap, USB Connection Cable, Shoulder Strap, CD-ROM
External Flash (Optional) - DMW-FL360L, Wireless channel: 1ch / 2ch / 3ch / 4ch
External Microphone (Optional) - DMW-MS2, Gun / Stereo selectable
Battery Grip (Optional) - DMW-BGGH3
