stoneinapond
Wow, I didn't realize we had so many knowledgable engineers and programmers here......
"..a few lines of code.."
:shocked:
:shocked:
My left hand is using a follow focus, my right hand holding the grip on the rig, if I ever develop a third hand I'll use a trigger however. :thumbsup::grin:I'm always amused with people whining about this. This is the solution, anytime you need to bring up diplay info or roll camera you can do it without actually touching the camera:
http://shop.panasonic.com/shop/model/dmw-rsl1
There are some aftermarket versions floating around too but I have never tried one.
The one thing I was really really hoping for with a firmware upgrade was some more functionality with the wifi remote feature, now I don't think it is going to happen in this camera model.
:shocked:
I have thought of a work-around, I guess I could stick the trigger between my arse cheeks then squeeze when I needed the display information to reappear.rogar-Dolar(DBG):
:shocked:
:shocked:
It's likely a series of if-then statements within the firmware that hides the display information after x seconds. Not exactly the most complex programming concepts at work.
Lol
I must also add how amazing it is that people on here expect perfection from a $1,200.00 camera when typically a $6,000.00 camera isn't even perfect. In fact even RED has its flaws.
As a developer myself I can tell you very little happens in a couple of lines of code.
I really don't think the software complexity is preventing Panasonic from changing this. Even if the software fix was 50 lines of code instead of 5 lines of code, it's just modifying an existing feature....
Lol
. . . I hate having to touch the LCD every 10 seconds to see if my audio levels aren't clipping.
Perhaps headphones would be a viable solution?
I always use headphones, but I have a hard time hearing the headphone mix when I'm recording a live band or any relatively loud source.
There's just a lot of important information that disappears while recording. Maybe I have mild OCD, but I would much rather see that stuff at all time.
