GH2 Manual setting not allowing exposure adjust?
Sideeffects
Hi there-
I hope this is not to lame but I'm having a tough time here (I've moved to this cam after shooting 20 yrs of TV on broadcast cams)... Problem: GH2 set to manual mode seems to block me from making any exposure adjustments. I have control of shutter, ISO, but not aperture?
I'm set to 24H, no hack (yet), aftermarket lens (EOS w/ a Kipon ring with iris), and in Movie mode on the dial.
EXAMPLE: Say I want to stay at 50fps or 125fps for shooting in 24p, am I stuck having to use a matte and ND's to get where I need to be?
I shoot moving from a motorcycle mostly in bright sun, the matte would be problematic with all the wind - really I'm looking at how / if I can control in-cam.
Any help? TX
So far I haven't used or even tried any "adapted" lenses on my GH2's, I use Lumix and Zuiko m4/3rds optics although I still have several EOS lenses. I've got a hunch your problems may stem from the adapter, and although it may have it's own iris I'm not sure it "communicates" in any way with the camera.
Be sure that in your configurations you have M (for manual) set in EXPOSURE MODE on the MOTION PICTURE menu (must have dial on top set to MOVIE to access this). If you have S (for shutter priority auto) set, then the camera will not allow you access to specific apertures as the exposure system tries to select this. With an "adapted" lens that does not "communicate" with the body it may not be aware of aperture changes. With EXPOSURE MODE set to M I think it would deal with the light coming in and you should be able to work from the exposure metering read out at the bottom of the screen.
2nd item I would look at is, do you have CONSTANT PREVUE and EXPO.METER both set to ON? (found in the CUSTOM menu - "C" plus wrench icon). The first allows the LCD and viewfinder to darken as you cut exposure and brighten as you add exposure, the second enables the exposure meter readout at the bottom center of the screen.
I would appreciate some feedback on whether or not this helps you, I'm currently writing an article on manual exposure with the GH2 in video mode and your response would be helpful.
I have not shopped for an adapter for my EOS lenses, I have the EF 24mm f2.8, EF 28mm f1.8, and EF 50mm f1.8 (original model) as well as a couple of "kit" zooms (18-55 and 55-250). The main reason being the reports of some problems with the models that have their own iris and the expense of those that actually "communicate" with the GH2 body.
One reason I converted to GH2's and m4/3rds optics was reduction in size and weight. Doing most of your shooting from a moving motorcycle, you might look into the Lumix 14mm f2.5. The wide angle should be more "moving" friendly and a .9 (3 stop reduction) or 1.2 (4 stops) ND might work for you very well.
You are using a manual mechanical lens adapter to mount your EOS lens, so there is NO aperture control of the Canon lens.
You will have to use a more expensive ( $400 and much higher ) electronic adapter if you wish to control your EOS lens electronically from your camera.
Tx guys -
Ok so maybe I'm a bit stuck with a mindset of having been using broadcast cams and for sports locking the shutter and using auto iris - no to mention this nutty GH2 manual.... So, that said, I should be able to set to "S" shutter and let the cam run internal exposure... I tested, but still cannot get it to stop down low enough for bright sky. I'm closing my iris on the adapter ring to the point of half way (beyond that and you get some vignetting).
I did have a thought of taking my EOS lens's and mounting on a canon SLr and getting them to 5.6 or whatever, and turning off the cam (holding that lens setting?) then remove and remount to the GH2 (assuming it holds) and running from there... I know "get some ND's" no time right now with a shoot this w/e and any matte bx worth buying is pricey (recommendations on matte bx?) Problem is when shooting bikes if you go above 125 shutter you get that effect of wheels rolling backwards etc... So I need to keep it low as well as matching the 24p - So, still puzzled
@Bruce - I think this answers some Q's for you as to my journey here? Let me know and I can be more direct -
Gregg
sideeffects,
Send me an email address in a PM and I'll send you the article I'm working on. It's almost done but it covers manual control of shutter, aperture, ISO, and some ND info in a manner MUCH simpler than anything in the manual. You can then do me a favor by commenting on what you find useful.
Just remember it's not finished, or "polished" yet.
It's written from the viewpoint of using strictly native m4/3rds lenses and you'll see how simple things get. I still feel for future events you may be best served by using the Lumix 14mm f2.5 lens. Tiffen ND filters in 46mm are inexpensive and I think that lens is particularly suited to what you want to do.
On a moving motorcycle a matte box is probably not a good idea.
I don't know what the focal length of your EOS lens you want to use is, but the procedure for "locking" the aperture from a Canon EOS body is simple but a PITA to have to do. Set the desired aperture in Manual mode, hold the DOF button in while you unlock and remove the lens. The aperture will be locked at that setting with as little as 1/4" twist with the DOF button held down but to be sure I would hold it until the lens is almost off.
I used to have to use that method for "locking" the aperture with EF/EF-S lenses on the Canon T1i to get manual aperture control in video mode (that model was video "crippled" with nothing but full auto exposure available in video mode). The lens would not be removed but with about 1/4" "twist" with both the DOF prevue and lens unlock button depressed all lens communication would be "disconnected" with the aperture "locked". The T1i then selected shutter and ISO to go with the amount of light coming in.
It worked until they came out with the 7D.
So further on in my quest- I did try and stop down (electronically) an EOS lens today, but no go... I'm not even sure how those lens adjust? I'd bring it to 5.6 and turn off the cam and remove it and it would be wide open. I looked at it in sunlight through both ends and can't see any sign of an iris. so I put back on the kit lens and have fill control. I guess there is no control of the GH body exposure manually. The only thing I can think of is I'm stuck w/ a matte bx and filters if I want to use those EOS lens...
Hang on, you shouldn't be in S mode for video. You should be in Movie mode on the circular dial - then you have fully manual shutter and Iso, and Wysiwyg exposure on the LCD. The aperture control will be whatever the lens and adapter provide. Go to the stickies at the top of the GX2 forum for more setup advice.
TX Graham - "S" meaning Shutter Priority, Not the S on the Dial, I am in movie mode.
Dingo- Tx for that, I did see you mention it on the first post, I'll go look for such an adapter, but to date I've not seen any electronic ring? If you know of one, I'm open, but as said, I will research
Somehow I missed that in a post above.
Refer to the material I sent you and insure you are in "M", not "S" in the EXPOSURE MODE configuration item in the "Motion Picture" menu (with the mode dial on top set to MOVIE). Until the electronic EOS to m4/3rds is actually on the market there is NO WAY to get the GH2 body to control aperture on "adapted" lenses.
Shutter Priority in MOVIE mode will not be a viable option for you right now except with "native" lenses and I still would not try to operate that way.
If what you want is for the camera to adjust exposure as you ride into shaded areas and then back into sunlight, there's another way. Set the aperture on the EOS lens mounted on an EOS body (set to manual) to whatever you want for desired "depth of field" effect, WITHOUT turning the camera OFF depress and hold the DOF Prevue button while unlocking and removing the lens (then you can turn the body off).
Set the GH2 MOVIE "EXPOSURE MODE" to "S" for Shutter Priority. It still won't be able to "read" the aperture you set but I think it will "work" with the light coming in. AUTO is now an ISO option (where it's not in "M") and ISO should adjust exposure as needed.
You will spend MORE for that, when available, than for the "native" Lumix 14mm f2.5 I suggested.
And the Lumix 20mm f1.7 could also be an option, costs a bit more (still may be less than one of those electronic EOS adapters) and may be more universally useful to you if you don't want a wide angle.
Tx guys- and Dingo, I went ahead and ordered the RR LiveLens.... so sleeping better, but we'll see-
I'll post after I test and shoot this job this w/e
GB
sideeffects,
Hi Bruce, I am unable to send a PM for some reason. Would greatly appreciate the chance to see your essay/article if you still have it kicking around.
Sincerely, Chris Poynton (Australia) --- www.YesYesMovies.com
