I've just got a GH2 and a 5" Lilliput GL569 monitor.
I've previously used GH1's, so have no experience with monitor use, and would like to check a couple of things to ensure I haven't got a faulty one.
Firstly, it displays the image in preview/record/playback - no problem.
However, it has four function buttons - two of which don't appear to work, and I don't know if that's just because of the GH2 and the signal it produces.
Ratio button is fine - switches between 4:3 and 16:9 (default)
Colour mode button is also fine - toggles RBG/Mono/Colour.
Underscan/Overscan button - does nothing, just blanks out the screen and says 'no signal detected.
Frame button (supposed to produce a 'safe' frame to let you know what's being recorded) doesn't work, as above, 'no signal detected'
On the plus side, the monitor displays a full image (no black bars) that is identical to the camera LCD image - so, presumably, no real need for the two missing features?
I'd just like to check with anyone else using a Lilliput monitor with a GH2 to see if mine is dodgy and needs returning.
Many thanks.
Many thanks.
