Lindquist Veteran Feb 11, 2012 #1 i just picked up the sandisk 16gb 95mb/s card from bestbuy. Can i use the 187mb hack with this card?
R royfel Active member Feb 12, 2012 #2 Most have only tested the 64Gat that speed, but in therory it should work..enjoy all 15 minutes.
M mr bill Well-known member Feb 12, 2012 #4 The 64gb card is SDXC, anything else is SDHC, so the 64gb card is faster..
T TheDingo Veteran Feb 12, 2012 #5 mr bill said: The 64gb card is SDXC, anything else is SDHC, so the 64gb card is faster. Click to expand... The SDHC format supports up to 32 GB memory cards. The SDXC format supports in theory up to 2 TB memory cards. ( 128 GB is the largest size currently being manufactured ) In theory SDXC memory controllers may be faster, but the tests I've run with actual cards show no real speed difference. i.e. A 95 MB/sec SDHC card appears to be just as fast as a 95 MB/sec SDXC card
Lindquist Veteran Feb 12, 2012 #6 ok thanks for info. i tried the 176mb hack but i switched to 100mbs flow motion patch. Only thing is i have a mac so i cant monitor the speed. stream parser wont work can i send some one a link to a 4 second mts file to test for me? thanks
