GH2 GH2 Battery Charger?
Boncrek
Does anyone know where you can get extra GH2 battery chargers?
I will hopefully soon own four GH2 batteries and wanted to have one charger for every two batteries.
Would make my charging life easier with only one battery change to worry about during a charge session.
I bought one from this eBay seller: http://cgi.ebay.com/BLC12-BATTERY-C...731?pt=Batteries_Chargers&hash=item231029cecb
It arrived in about two weeks and I've put it through about 30 charge cycles so far, testing it. It comes with a 12 V car adaptor, which could come in handy. If my digital multimeter is to be believed, the charging terminates at 8.30 volts, resulting in a small loss in capacity of about 20-30 mAh compared to when I charged the battery on the bench at 8.40 volts, the voltage to which it should be charged. But I can't verify that my meter is correct, so what I thought was 8.30 volts may have been 8.40 volts (1.2% difference, and my meter is rated at +1%, so the voltage could have been 8.40 volts)
Anyway, if you can't find a charger elsewhere, you won't lose much by paying $13 (including postage) for this one.
Guyburns, just fyi if the charger is undercharging at 8.3V, the small capacity loss of 3%-5% comes with much better cycle life. Overcharging just by a bit increases charge capacity but damages the cells. That is why conservatively designed Li-Ion chargers intentionally undercharge the cells, their end of charge voltage is set to 4.1V or 4.15V/cell instead of more common 4.2V.
