bgpixelman
Hi. I just got my GH2 and the JL dt454. Those of you that have this combo, how do you attach them together? If I was to simply screw the 454 into the tripod socket, it would block the battery door.
If I use a Bogen quick release plate to the camera and then screw the JL 454 into it, it would require a shim or spacer to make it fit flush. Then, I would need another Bogen quick release plate setup to screw into the bottom of the JL 454 so it can be attached to my tripod and/or bracket.
Any wisdom out there?
Also, on setting up the 454, the user manual did not include the GH2 so I emailed Juiced Link. I got a reply right away, telling me to set it up like the Canon 5d. Thanks.
Feel free to suggest any way that would be a better way to connect this stuff! Also, I will have to find a cable that would work, going from the 454 to the GH2.
