I'm having some trouble figuring this out. I've got pTools running on my mac under winebottler, but I don't undertand how I load:
1. Present hacks people have made into pTools
2. The firmware on the camera itself.
Also what version number should I use for the firmware when saving it since I've got a 2011 model camera?
Also should I check off "Prevent Version Compare?"
Oh I see. Thanks for the information!
But, how about between the pre-2011 model that have been hackable and 2011 models or those that were once hackable? Are there any differences or improvements made in the newer ones?
The answer is found here;http://www.personal-view.com/talks/discussion/117/gh1-firmware-hack-faq#Item_11
Make sure you have the newest version of Ptools installed; created 05/29/2011
You want all three boxes checked, and when you check Version Increment, there will be a little box down below that shows a green 1 change that to 10. Spend some time reading the FAQ's, as most answers to your questions are there.
good luck.
As far as loading other people's patches, just unzip in the same folder as Ptools, open up the firmware you want to hack, and you will see some letters at the bottom of the screen-the ones that have patches associated with them(the patches you downloaded), will be colored and selectable. The patches themselves, such as the Reliability Hack, are ini files, and will have names like; "setj". So, when you click on the letter J, it will load that patch onto the firmware. rename the firmware 1__33.bin, oor 1__32.bin, or whatever, and save. I don't think the number you use makes much difference, as I saved mine as 1__22.bin, 23, 24, etc, for the different patches.
Some generic 16GB class 10 card I got from Microcenter. Seems to be working great.
