greetings all --
as this is my first post to the forum, i think it polite to formally say "hello". i've been lurking here since last october or so when i bought my gh1. this place has been a wealth of great information about my camera -- my thanks to all of you.
that being stated, i have not been able to find a fix (read: similar situation) for my current problem...
since i purchased my camera, i have changed the firmware via ptool countless times; playing with bitrates, frame sizes, etc. however, this last time i modified the settings in ptool to allow for 48kbps audio capture. this seemed to work well -- the audio indeed sounded of better quality -- but rendered the captured files unplayable in-camera. this was, of course well documented and i expected the camera to behave as such.
in any event, last week i attempted to "re-hack" the camera without the audio modifications so that i could again play the files back in the camera. this, unfortunately, to no avail. on a fully-charged battery, and with the appropriately modified firmware on the sd card, when i press the playback button and select "yes" on the update firmware dialog, the camera does not proceed through the update process. i am only prompted to turn the camera off and then back on.
i have scoured the forums and tried all of the possible solutions that i could find, but am still unsuccessful. i suspect that this problem has something to do with the modification to the audio settings that i made, since that is really the only difference from my previous (and quite successful) changes to the firmware settings...
has anyone had a similar issue? any suggestions for a possible solution?
thanks a bunch in advance.
cheers.
-- ike
cheers.
-- ike
