Gh13 import into FCP 7
thebighappyface
How do you import into final cut pro 7 with the gh1 with tester 13 hack? Will it work? I want to get a gh1 and hack it but I'm afraid it won't work with final cut pro. If so how do you import files from the sd card?
Hacking a GH1 or GF1 doesnt change anything regarding FCP, you still import MPEG and AVCHD the same as you would a stock Lumix. Whatever workflow you used before with FCP, keep using it after the hack.
You log and transfer the AVCHD footage from your copied PRIVATE folder, then you run it through compressor to remove pulldown.
Copy "Private" Folder to Hard Drive.
In FCP, goto Log & Transfer
Select Clips.
Once injested, you can use JES or Neoscene for pulldown.
Please read FAQ sticky.
I've been using the the gh13 and I just use Log and Transfer and import the footage. There's no need to do the pulldown is there.
I remember when I had it set to standard it was come in as 60i now it's straight 23.97
But with the hack it's just drag and drop after log and transfer.
Thats if you ticked for a native 23.976, others wise you will need to pulldown. Not all users do.
Cheers
