Gh1 xx9xx with 1.34 can it be hacked?
I have a GH1 and the number indicates it was made in 09 and when i go to service mode it shows 1.34. Can it still be hacked?
if its 09 and in original condition it should be able to unless repaired. have you tried at least?
I have not tried to hack it yet. This was purchased as "everything original" accompanied with the serial number but when I got it I discovered the possible updated firmware.
Do you know how to tell if it has been hacked vs this 1.34 firmware?
Under these circumstances I think the quickest, and perhaps only, way you are going to find out if your camera is still hackable is to go ahead and attempt to hack it. You've nothing to lose by trying.
Try and install the hack software. My guess is it has been "serviced" because normally version only says v1.3 not v1.32. Version 1.34 is definitely not what you want to see.
