Essami
Hi,
Im seeing both vertical and horizontal artifacts on my images and I did a few rough tests tonight to determine best ways to work around this.
Vertical artifacts are visible mostly on skin areas at all ASA numbers if I'm underexposed even slightly. Vertical lines are sharp, a few pixels wide and always fixed.
Horizontal line artifacts appear roughly after you are at or go higher then 400 asa. Its on all of the image but more visible on dark areas, they are thicker then vertical line artifacts, blurry and also seem to fluctuate slightly.
So to me at the moment my conclusion is if you want clean image you need to shoot under 400 asa and do not underexpose. If I'm going to be under exposed and there is no alternative but to go higher asa I find 400 asa just about usable for my own art stuff but not for pro work. If it's pro work prepare to light it up
Sami
Sami
