GH1 Movie Mode: Banding or FPN below 800 ISO?
emory
I posted this in the GH1 hardware forum, but I just realized it is more appropriate for the workflow forum. Sorry for the double posting; I'm a newbie and it won't happen again.
I think I have read every thread on the subject of banding / FPN, but one point is not clear to me:
Hypothetical case: Studio portrait situation with dark grey background tapering off into jet black. Soft box to one side of subject so that shadows on the dark side taper off into jet black. In other words, adequate exposure on face and gradation from purest white to deepest black. Other examples: person at window of large room, light falloff to jet black in background; entertainer on dark stage lit by a single spotlight.
In MOVIE MODE (720), would one see banding/ FPN in the darker areas at say, ISO 400 ? ISO 800 ?
My reason for asking: It is difficult for me to get hold of a GH1 for testing and returns are nearly impossible where I live.
Thanks for any insights.
FPN and banding are two separate things. The trick to avoiding FPN (my solution at least) is to make sure your skin tone (or your subject) is exposed properly, or maybe even 1/3 stop overexposed. Then, in post if you bring the image down by 1/3 stop, the skin tone looks normal and FPN doesn't show up. This also pushes noise down into the blacks and the image looks good.
Banding is an issue with the 8-bit codec. Your first scenario with the grey background may have some banding. Any example where the light falls off to look like a gradient risks banding. The entertaier on stage likely won't have banding because it is very contrasty.
Thanks for your helpful response, dvbrother.
Interesting solution for FPN: the opposite of what we used to do with color slide film (UNDERexpose slightly to avoid blown-out highlights).
As for banding, apparently my definition was way off. It seems to be the phonomenon one often observes in blue skies on older LCD monitors: gradation in steps rather than seamless, like the difference between TrueColor and 256 colors on a graphic card setting.
Since the codec only has 8-bits, there appears to be no solution. Would you consider it a deal-breaker?
I too am used to underexposing a bit, and it's a new concept for me. However, this only has applied to me when you want subject of the scene to be middle gray or darker. When your subject is above middle gray (i.e. flesh tone normally exposed) then the FPN doesn't appear where it's unwanted. It's in scenes where you want to be moody that you need to expose hotter then print down in post, so the FPN doesn't manifest.
I don't consider banding to be a deal breaker. I actually haven't noticed it that much, but then again I don't spend lots of time shooting large gradients like blue skies. I have really enjoyed my GH1 and don't regret it at all. It has given me cinematic advantages that surpass my wildest dreams for $1200.
If I was using it to make a living, and had clients to worry about, I may balk at the limitations of it's AVCHD codec, but for my own creative purposes, it has been wonderful. Here's a link to the trailer for a short I shot with it. I didn't have any problems with 8-bit banding :
http://www.vimeo.com/7449911
And this one has a lot of sky sunset shots where banding might occur but didn't:
http://www.vimeo.com/6804166
The second shot (of the water reflecting the sky) actually does have some banding, but I think the beauty of the shot negates it. You can judge for yourself.
Hi Todd,
(Sorry if I just blew your cover, but the links you provided were pretty conclusive.)
First off, thanks for your continued help and the links.
Secondly, I saw those two vimeo clips of yours a couple of months ago and found them fantastic. Perhaps more than any others, they convinced me that the GH-1 is worth pursuing. Then I got side-tracked by the FPN / banding issues I began reading about.
As far as banding is concerned, it seems to me there is some circular banding in the sky of the Plaza Art Fair clip at approx. 0'24" -- but that could be due to my PC monitor. It is by no means as pronounced as the banding around the light bulb in the Zacuto shootout Webisode 1:
http://www.zacuto.com/shootout
And FPN does not appear to be an issue for you, nor was it mentioned in the Zacuto shootout. But it CAN look pretty disconcerting:
http://www.vimeo.com/8500073
Thanks again for your help. And I loved your "Blade Runner" parody:
