GH1 Cam - PAL 720/50p video with NTSC 720/60p video on a 25fps timeline..
Desertfox
I shot 85% of my video with 1080 25p with an HMC 152en. (PAL)
I also shot 5% 720 50p with the HMC 152en. (PAL)
This two clip will be edited on a 25fps timeline. HD
The remaining 10%:
Now I have a GH-1 (NTSC) as a B CAM and I'm not sure which format I should use in order to fit in the 25fps timeline.
1080 X 24p (60i) then somehow convert to PAL OR 720 x 60p then somehow convert to PAL then Up rez to 1080 x25p?
Any suggestions?
Is this humanly possible?
Am I in trouble?
Any one in the know out there? I have to shoot tomorrow.
Oh am I very worried. :(
No worries. Shoot in 1080 24p. Remove pulldown through usual method to get to true 24p. Then open the file in Cinema Tools (part of Final Cut Studio), and select Conform to 25p. It will speed up your footage by 4% to perfect 25p. This method requires no transcoding, and takes only a few seconds in Cinema Tools to accomplish. It will give you a perfect 1080 25p clip that you can drop into your 25p timeline. Just remember that Cinema Tools makes the change to the original file, so you might want to make a back of the 24p file before conforming. Unless you're dealing with very audio pitch sensitive footage (ie music perfomance, etc), no one will notice that the 24p footage is playing 5% faster. In fact, all Hollywood released films onto DVD in PAL land employ this method.
Good Luck!
-Michael
Thanks Michael!
What if I shoot the GH-1 at 1280 x720 60p ? Can I also just conform and Up scale the footage to 1920 X 1080 footage in order for me to edit and fit it in a 1920 X 1080 25p timeline?
There will be no slow motions whatsoever... no music just people talking at a conference. And mixed up cameraman with a mixed up format.
Cheers
Yes, but I would not recomend it. You would first need get the 720 60p footage to true 24p, which can be done from 60p, and actually looks quite good. However, it is a considerably slower process to go from 60p to 24p than it is to shoot in the native 1080 24p an simply remove pulldown to output clean 24p. Also, why would you want to go through all that with 720 60p, only to upscale to 1080 when you can start at 1080 24p.
The bottom line is that you need true 24p to conform to 25p in Cinema Tools. Your best and highest quality bet is to shoot in FHD (1080 24p), remove pulldown, and conform.
-Michael
Thanks again.
I see... So it's actually OK to shoot the (NTSC) Gh-1 at 1080 60p and mix it with my HMC 152 1080 25p by conforming the GH-1 file. For a 25fps timeline.
The thing is, previously I shot with the HMC 152 with 2 different formats 720 50p indoor conference (which has a video look) and rest of the footage with 1080 25p outdoor shoots (film look)
I will be shooting at the indoor conference again and thought of emulating the (video look) which I took with my HMC 152 previously. So I thought shooting (PAL) HMC 152 as my A-CAM at 720 50p and (NTSC) GH-1 as my B-CAM shooting at 720 60p might just do the trick.
So I guess I should just shoot the HMC 152 at 1080 25p and GhH-1 at 1080 24p (60i) just to play it safe.
Remove pulldown: I roughly know what it's about but do I need another software to do this? Or it's just part of the conform process for Cinema Tools? Is there another step before putting it in Cinema Tools?
Thanks again if you have any comments.
I'd try first go from 60p to 25p in one conversion step with or without frame blending on a take by take basis - that's basically how I deal with 60i footage I get handed on a weekly basis. 24 to 25 conversion does not look pretty unless just changing the speed of the playback but that will not work in a multi-camera set up.
Yes, shooting true multi-cam, where you would want to use say sound from an external source across all the shots while cutting from camera to camera may be a bit of an issue. But if the 24 to 25 conformed footage is mostly b-roll or using its own audio track, I think I would still prefer to shoot 1080 24p and just conform to 25p.
Just a thought - but even doing true multi-cam, what if he were to sync the 1080 24p footage before retiming to 25p, then pitch the audio back. Depending on how much sync sounds, it might work out OK. Just use the picture and sound from the camera, instead of dropping in only picture.
