zcream
EDIT:- Manual Video on GF1. There are no need for these hacks. v3.30d and higher of ptool allows full manual video mode on the GF1. Here is my writeup.
http://www.dvxuser.com/V6/showthread.php?t=215526
This is to summarize video settings for the GH1 and GF1.
For the GH1, the best description is in this post.
http://www.dvxuser.com/V6/showpost.php?p=1825226&postcount=7
by
Bradley Kents
1. Select the Creative Movie Mode on the top mode dial (that's the little movie camera icon, plus an M). Set this and forget it -- don't wander from here.
2. Then hit MENU and bring up the MOTION PICTURE prefs. Select M for all manual.
3. Press-rotate the front dial to set your shutter speed to 1/60. Again, set-and-forget. Don't change it! (Seems like we're treating this like a video camera -- duh! makes sense!)
4. From here, you press-rotate the front dial to adjust your exposure (kind of noisy for video recording!).
5. This approach will work well in all but very low light conditions and very bright conditions.
So let's turn our attention to ISO and ND.
ISO
I suspect we can all agree that we want to use the lowest ISO possible. But as light levels drop, we can compensate by bumping the ISO up to 200, 400, 800 and 1600. The penalty here is added noise. (And, yeah, you want to add light, if possible.)
ND
Then let's step out into a very bright and sunny day. Unlike video cameras like our 170, the GH1 has no ND filters, so I was thinking of going with the Philip Bloom suggested Singh-Ray Vari-ND (sized for our largest lens, then add step-down rings for others). For bright conditions, this sounds like it would essentially become the new iris -- exposure would be largely set there.
by
Bradley Kents
ISO
ND
