GH1 60p to 30p in FCP timeline?
jackcklam
I wonder what's the easiest way to take 720 60p footage from GH1 and edit in FCP7 for 30p (29.97p) output.
1) After I use log & transfer to convert the mts to ProRes422 59.94p mov files, if I just drag these clips on to a ProRes422 29.97p timeline, it seems to work fine. Should I be concerned about any motion artifacts? Should I painstakingly convert all the 59.94p files to 29.97p in Compressor before I even start editing?
I'd expect such 59.94 -> 29.97 conversion to be very easy for FCP to handle. It simply needs to throw away half of the frames.
2) What about slow motion? For example, if I apply a 50% speed change to a clip on such timeline, is FCP going to create a smooth slow motion using all 60 frames? Or is it too dumb to do that and would give me a jerky slow motion by spreading 30 frames over two seconds.
3) What about cutting in a 59.94p timeline, then copying the clips from the timeline on to a 29.97 timeline? Am I gonna run into problems with the cut points being shifted and messed up?
