GH1 24p question: pulldown vs no pulldown...
Sorry this may be a stupid question, but I don't understand the difference between pull-down and no pull-down.
After following the recommended procedure of doing 24p pulldown via Compressor, I don't really notice any difference when viewing my 1080/24p clips in FCP 7.
I'm sure I must be missing something. Can anyone explain why it's necessary to do the 24p pulldown removal, or maybe just point me to a link that shows 24p GH1 footage before and after pulldown removal.
Thanks very much in advance,
- Nick
Pulldown removal removes the interlaced frames that are created every 4th and 5th frames in order to change 24p footage into 60i footage.
Basically it is creating extra frames in order to fill 30 fps with the 24.
Each frame has two fields. For 3 frames, these two fields are parts of the same image.
(AA) (BB) (CC)
but then in frames 4 & 5 you get a combination of two frame's fields (CD) (DE) with frame 6 being (EE).
So the sequence continued looks like this:
(AA) (BB) (CC) (CD) (DE) (EE) (FF) (GG) (GH) (HI) (II)... and so on.
[See the image below for a better representation]
Now when you watch a video on a progressive output such as a PC monitor, and there is fast motion, you will notice that every few frames there will be that interlaced frame. Different lines in the image will be offset and out of sync with each other. It is only for a split second, and many people watching may not notice or recognize it.
Ultimately, removing the pulldown takes that extra frame created by (CD) (DE) and turns them both into (DD)(DD).
(AA) (BB) (CC) (DD) (DD) (EE)
Now it removes one of them. What you end up with is 24p footage that is what you would expect:
(AA) (BB) (CC) (DD) (EE)
It's a bit hard to wrap your head around, but that's the best I know how to explain it.
This image shows the process of inserting the pulldown a little better. Though in theirs the lettering is a little different, their just showing the interlaced images in a different part of the process.
Their example: (AA) (BB) (BC) (CD) (DD) (EE) (FF) (FG) (GH) (HH)...
My example : (AA) (BB) (CC) (CD) (DE) (EE) (FF) (GG) (GH) (HI)...
