I happened to stumble across the GF2 and see it is priced at $699 with the 14mm f2.5 lens. The lens I know lists in the middle/upper $300s, so that turns the kit into a $350 lens and a $350 body. It's a 12mp cam, the same size but different configuration than the GF1.
So the first question really is more about usability for a second or third or whatever cam ??? Anyone have any experiences, good bad or indifferent ??? I have GH2s ordered so I would be trying to supplement those with this, unless that idea sucks.
The next question would be about any possible hack. I didn't follow the GF1 hack at all so have to knowledge of what happened there. I assume the same hack as the GH1 was used on the GF1 too. If that assumption is correct, would a GH2 hack probably work on a GF2 too ??? Or are they significantly different enough to have completely separate firmwares ???
Thanks for the input !!!
