roxics
Set to Motion JPEG, the frame rate is 30fps, and lower resolutions including 848x480, 640x480 and 320x240 pixels are also available. Set to AVCHD, the resolution is fixed at 1280x720 and the frame rate recorded at progressive 50fps for PAL models or 60fps for NTSC models (the native sensor output in each case is 25 or 30fps respectively).
What does that mean? The sensor outputs 30fps but records 60fps in AVCHD mode. How does that work? Would have been nice if they included 24p.
