Getting that "film look" with the HVX200
Steve Shovlar
DVXuser Sponsor
OK I am probably setting myself up here but I would like to hear what settings people are using to get that distinctive "film look".
I am not taking about the lighting side of things. I am talking about what settings you are using on your camera. Master Ped, sharpness etc.
There is no definitive answer to this. However, I'm sure most will agree that you should have your settings to a 24 framerate. Also, the "film-look" usually means higher production value, so more than anything, lighting and composition should be on the top of your list.
Yes I agree with this, though being in Europe 25P is the only option.
However, the camera can be setup to mimic the gamma curve of film, by adjusting the ped, sharpness, etc. That's what I was getting at.
We're getting this question in HD now? Argh!
Lighting is the only step in the equation that you'll need for a true "film look". Color and all that is subjective. If you can figure out how to light a set or location perfectly, then you're good to go. Try mimicing different lighting styles from other movies for practice. Figure out how they did it and learn what tools work best.
For specific settings on the camera, you'll just have to test that out for yourself and see what looks good to you.
It'd be good to have some scene file settings from people though. I know the HD100 users are swapping lots of scene files settings to get different looks.
Almost. Control over depth of field is a close second to lighting, because it allows the creators to direct attention to the important narrative elements. And in my opinion, 24P follows those in value, but at a respectable distance. But you know what is really true? The audience will buy anything that grabs their attention and holds it (not effects, however, unless you are under 4 years old.)
Learn writing first, the needs of actors second, the needs of editing third, lighting forth, and read all the tech stuff when you're in the bathroom. it makes for great entertainment "on the pot".
Just want to clear something up. What you're saying has some truth, but still. It's complete bull****.
If you run along a filmset using a 3ccd SD videocamera (example, the PD150), and shoot about the same moves and angle as the actual filmcamera, you'll see an enormous difference. Just to use an example, try watching a behind the scenes DVD from a big budget movie, like The Matrix, Lord of the rings etc. -where you see them filming a complete (lit) filmset. The difference is huge.
My answer is:
If you want to create what I like to call "that other world feeling" (beeing filmlike fotage), you need a number of things. - One alone, like for example lighting, is not going to do it for you.
A quick list on the top of my head: 24p, colourdepth, depth of feild, black contrast, appropriate color corrected mood setting colors, the right type of light; beeing not direct sunlight or backlight, textures that reflect this light in a way the cameras resolution captures it (this is better proven than spoken of) and lastly good movement, beeing conscience handheld or stabilized.
please argue with me,
:nads:
Since you did specify in your question that you're interested in discussing camera settings...
There are many distinctive "film looks." As illustrated by the many presets of Magic Bullet, each designed to emulate a different kind of film look. So assuming you might be referring to what Magic Bullet calls the "Basic" look of film.... with the HVX (and DVX), it's easy, as simple as shooting at 24fps, and using one of the Cinelike gamma settings and cinelike matrix. You're there. The other settings will give different results depending on the specific "filmlook" you desire.
That said, having a shallow depth of field (using 35mm adapter) is essential to getting a film-look so good it will fool almost everyone.
I'd also love to see a place on these boards where people can share scene file settings to get specific looks.
Thanks you R Gale that was more that I ws getting at. Not lighting, 35mm adaptor etc. I have all that. I want to talk about the camera settings.
Straight out of the box the HVX is setup flat and neds adjustments to give that certain look. Not just shooting i720 24 (5)p on dial number 6 CineD.
What about image sharpness settings, gamma curve, master Ped etc.
It would be very useful for there to be a seperate forum section where such settings could be discussed.
Got your camera set up to look a certain way and want to share it with others on here? post it in a new dedicated section!
theres this software I used last month called "magic bullet" and it was great!!
I highly suggest finding this magic bullet software to get a TRUE film-look
I hope you're not planning on skimping on the lighting angle as that's pretty damn import. We've all seen a lot of stuff that was shot on this camera. Usually the difference between the stuff that looks like film and the stuff that just looks like sharp video is the lighting. Bad lighting can even make one sometimes question if something on film was really shot on film. I've seen more that a few 16mm films that were so flatly lit I though they were shot on an XL1 and just converted to 24fps.
Anyway, I suggest you go ahead and, aside from setting the FPS to 24p, just turn on all the "film-like" settings in the camera. Everything labeled as such gives you more of a film look. I also find pushing down the master pedistal will give you the crushed blacks of film better. Everything else is preference.
I strongly disagree. Many of the best directors often shoot with a pretty large depth of field with some of my favs working in deep focus. This, is an artistic choice. 24p however is a factual difference between video (previously) and film and far more important.
I think the HVX 720pn, 24fps, cinegamma D setting is the best "out-of-the-box" film look of any small camera I've seen. The other things are more a matter of taste that you'll have to decide for yourself based on the material you're shooting, the aesthetic of the script, location, available light, etc... For instance, if you've already got a very high contrast scene where the shadows are nice and rich, you're not going to need to drop your master ped --- you might even want to raise it. These are things that can't really be "preset" in-camera. In fact, I wouldn't even recommend thinking of setting up your camera based on "presets." Every scene needs to be looked at and thought through independently. Using one (or even six) preset(s) that you like in a certain situation for ever other scene will get you into a lot of trouble. The HVX is not magic, it's just tool, and you have to learn how to use it.
I also agree with David B. --- DoF is another artistic choice to be made and thought through scene by scene. Shallow DoF is not a prerequisit for creating "that film look."
The 4 main differences from film to video (as taken from an instructional dvd from Kodak):
1. progressive frames vs interlaced (the HVX has this)
2. depth of field (buy a Redrock M2 as a workaround)
3. latitude film 14 F-stops vs video 7 F-stops (reel-stream is a workaround)
4. sorry for not remembering this one.. I think it was about having an optical viewfinder instead of counting on tiny LCD screens. Or it might be about the resolution, which I see as a non-issue since the introduction of HD.
of these points, I feel #3 is most overlooked on this forum. Having the latitude of film is an INSANE advantage. You will NEVER get the "professional film look" as long as the video format only handles 7 F-stops (for people unaccustomed to general photography: 7 F-stops means correct exposure for either sky and ground (where the other is respectively over- or underexposed) while 14 F-stops means correct exposure for both sky and ground)
So when we've got an HVX (progressive frames & HD resolution), an M2 (depth-of-field) and a reel-stream device (for an additional 2 F-stops for a total of 9) this means we are getting DARN close to film... Of course, without a proper script, our movies will suck anyway :)
I'm constantly amazed that people know more about color sampling than they know what they want to make a movie about... People who know their HVX's better than their own feelings.... It's hard to do, but getting in touch with one's feelings is much more helpful in filmmaking than knowing all these photographic issues... I can mention both European filmmakers as well as American filmmakers who just don't know anything about photography, but who remember the one single thing, which is not only the cheapest part of filmmaking, but strangely enough the most important: THE SCRIPT...
Okay sorry for that... I've snapped out of it :) I'll get to the screenwriting forum... soon...
I agree with Ursa on every point. However, some of us here ARE technicians. And in this field a good technician with all his geeky knowledge can be every bit as valuable as a good screenwriter who knows his heart and the human condition. Yes, it all starts with a great story, but the execution of that great story is ultimately just as important. Who here hasn't seen a good script killed by bad lighting, acting, production design, cinematography, directing, music, etc.. I applaud anyone on these forums who is striving to learn his/her craft, whatever that might be.
proximity said:
... Just to use an example, try watching a behind the scenes DVD from a big budget movie, like The Matrix, Lord of the rings etc. -where you see them filming a complete (lit) filmset. The difference is huge.
:nads:
I agree! We looked, Lord of the rings, behind scenes and every time you see video clips of same scenes, those just looks amusing, even there are light etc. like on film... Video just don't looks so credible. Anyway I have seen very well done video's with film look feeling.
I have a huge amount of lighting and am well aware of its value. I have 2 four bank Kinos, Three dedos, 4 1K Desisti Fresnels, 3 650 Fresnels, 3 300 Fresnels, 3 575 Arri HMIs, 1 1200K softbank HMI, 1 4K Fresnel HMI.
I am afraid this thread has gone off at a complete tangent from what I was getting at. Partly my thought as I should have perhaps worded it better. Rather than say "film look", I should have said what camera settings are you folks using on your HVX200.
You can't compare Lord of the Rings 35mm Prints to video. They did huge color corrections on that movie before it went on screen. It is an 100% mistake if you think you can buy a video camera (even a HDCAM SR) an it would be filmlook out of the box. There is no such thing. Period!
One of the first lessons in digital filmmaking is: If you treat it like film, it looks like film.
So you have to go the whole nine yards. Lightning, DOF, directing, acting, editing(!) and color correcting.
I did electronic cinematography with a Sony 900 and a Panavision Lens that cost over 1'000'000 Bucks (that spells Million) and guess what. It looked like crap! But after the Color Correction and all the editing. Whoaa!
But then again, who am I to know ...
Man what a light you have!:happy:
There is a sticky handling scene files, did you see that?
Out of the box it does not look like film. Not what you are used to see in cinemas or on dramatic tv. End of story. You can exchange your camerasetting. You can even write this in big letters. It won't become any more true. Out of the box even well lit 35mm needs color correction. I spend some time in tinseltown. Been there, done that. You may come close, but ...
Here some settings that were recommended in several threads in this forum. (though some refer rather to noise which came out to be rather a none-issue those settings might be considered, too) I personally did 'nt have the possibility to try them but I will do so as soon as I get a HVX in my hands:
Here are some suggestions for scene file setting, what I've liked so far.
Daylight/Sunlight
Detail "0"
V-detail "0"
Coring "+3"
Chroma "-2"
Master ped "-4"
Cinelike_D Gamma
Cinelike Matrix
Interior tungston (5 stop detail range keeping skin tones at 50IRE)
Detail "-2"
V-detail "+2"
Coring "+3"
Chroma "-1"
Master ped "-4"
Cinelike_V Gamma
Floro or Normal Matrix
My suggestion would be to set master ped down to -6 (which makes black black on the DVX), see what effect that has on the blockiness (whether it disappears into the shadows).
Compare CineV and CineD (CineD is apparently more noisy, but at least the noise looked more "organic").
Try pushing the coring right down to -2 in CineV to see if that reduces the blockiness.
That's all I got! Let us know how it goes
Hello all,
We recently conducted a film out test with footage from the HVX. A very special thanks to Postworks New York for their incredible help and expertise. I promised to report back the results so here they are.
Footage:
The footage was all shot in 720P mostly with chroma +3, detail -3, coring +3, master ped -3 and cine-d
OVerall Impressions:
WOW - amazing, truly film like. The footage truly stood up to the blowup. Looked amazing.
