I have barry's book, and have read the SD card section, and have checked the manual, but did not see anything on how to get the CD contents onto the SD card, and then accessing that info. Help? thanks
You need to format the card using your camera. This will create a directory structure on the card. Take the card to the PC/mac and you will see that the scene files directory on Barrys CD mimics that on the newly formatted SD card. simply copy the txt files from barry's cd into the same folder on your sd card (using your pc/mac) and the camera will be able to read them.
It is easiest if you set the camera into P2 mode rather than tape to load and work with SD cards as there is an extra menu option of 'card functions' which doesnt appear in DV mode.
The instructions are all in the manual pages 55ish I think.
One word of caution. Format the card and then make sure you save your own settings. Once you load a new set in, your own settings will be gone for good. The initial factory settings can be retrieved at any time through the camera tho.
