M Mark-P Well-known member Aug 21, 2017 #1 Can you use a FDR-AX100 and open the aperture up until getting a shallow depth of field effect like you can with a DSLR? Thanks.
geani66 Active member Aug 22, 2017 #2 Not much. If you get closer to your subject then the answer is yes. It's a 2.8 lens and 1inch sensor.
M Mark-P Well-known member Aug 25, 2017 #3 Isn't 2.8 good enough to get a shallow depth of field effect? Is the issue with the size of the sensor? Thanks.
