Richard Crowley
In general "Genlock" inputs are designed to accept either full composite video, or just the sync part (without the picture), aka "black burst" or "composite sync". I would be very surprised if you couldn't take the composite video output from the EX1 (via the fiddly miniature connector and adapter cable to RCA) and feed it to the EX3. Or the SDI output from the EX1 and through a converter box to composite to feed the EX3.
All this applies to traditional 29.96FPS NTSC. I don't know that any of the traditional "genlock" behavior works for other framerates, and especially HD???
If you have several sources that you need to feed synchronously into a traditional switcher, you can use the one that does NOT do genlock and use IT as the sync SOURCE to lock all the other sources (and the switcher) TO. I have done this many times with live-switched "image magnification" (just as your orchestra is considering). I have genlock cameras and a genlock switcher, but the laptop computer (which is the source for graphics) does NOT have genlock (none do). So I simply use the laptop computer itself as the genlock SOURCE and sync everything else to it. Works just fine as long as the computer (or whatever source) remains operating and connected
HOWEVER. If you are running SDI into an SDI switcher, then you probably don't need genlocked cameras at all. Since SDI is digital (by definition), the SDI switchers that I have investigated inherently perform the function of "frame buffer" and do NOT require synchronous inputs. For example, the For-A HVS1000HS Hanabi Switcher accepts both SDI and composite (and component) inputs (asynchronously) and switches them all together, even doing various kinds of image manipulation between HD and SD sources, etc. And it is a full-service SEG and DVE processor in the same box. And the Newtek TriCaster.
