M m1best Active member Apr 27, 2006 #1 With the exception of noise will a standard 5500 watt generator be ok with lights or do they flicker?
P PDX_DVX Veteran Apr 27, 2006 #2 You run the risk of them flickering. I think some of the Honda generators have a clean sine wave and will not flicker though....
T tim_brown Well-known member Apr 27, 2006 #3 You don't specify HMI or tungsten. An HMI with an electronic ballast won't flicker on a regular put-put as long as it has enough juice, but as PDX DVX said, anything else might.
