Ge reveal bulbs color temp?
Does anyone know what color temperature GE reveal bulbs are? Are they closer to 3200K or 5600K? Any issues with using them and mixing them with pro lights?
Thanks!
I have found the daylight temperature CFL bulbs are much closer than the "reveal" bulbs, which were not close enough to work.
They're cheap enough to get a few different wattages to tune in a light to your taste (since all but the most expensive don't work on a dimmer.)
Plus you can get more light out of a practical if needed, they can put out the light of a 200 watt bulb for less than 60 watts, which may be the max rating of the lamp.
This is in no way scientific, but I feel like they fall near the middle (roughly equivalent to Tungsten with ~1/2 CTB). I bought them to use as practicals in a short I did in December.
I was balanced to daylight, but wanted the practicals to still have a slight-tungsten glow. They worked perfectly. Plus they work better than CFL with my dimmers :)
I white balanced on a regular bulb and got 2600
I white balanced with the GE reveal bulb and got 2800
They are definitely cooler, but not by a lot (if my test was accurate).
if your town doesn't have a Lowes, it sure as beans doesn't have a Home Depot. think Walgreens, Longs, CVS, Rite Aid. all on the same block haha
