[FS: General] Fully Motorized Professional Pan/Tilt Head
KAG
SOLD!! ---- SOLD!! ---- SOLD!! ---- SOLD!!
This PROAIM™ Pan/Tilt Head is designed for DV, HDV and Broadcast cameras up to 19 lbs.
This is a 100% knock-off of the Camera Turret PT-20 head by a company in India. It's constructed and functions exactly the same. I've owned both and couldn't tell the difference.
It is in excellent, near-new condition. Everything functions perfectly. It has been used 5 times on film shoots.
I am selling it because my shooting projects aren't using it as much as I thought.
Pans and tilts cameras smoothly and accurately with precise, proportional joystick control.
The creative movements from this head can be fully utilized by using it with crane arms, tripods or any other remote operating situations, and allows you to create extraordinary videos.
It works on 24 volt power through the included AC adapter and easily accepts external 12VDC or 24VDC battery power through the included XLR-to-cigarette plug adapter cable.
Has two high torque, coreless DC motors that rotates (pans) and tilts the head 360 degrees.
Speed is variable and is easily controlled and adjusted by "Speed" and "Dead Band" potentiometers on the control unit.
The joystick controller includes both Logrithmic and Linear control capability.
In Linear control each degree of movement reflects an equal amount of speed increase.
In Logrithmic control the first half of the joystick reflects a smaller increase in speed, while the second half increases faster to catch up to full power. This makes slow speed more controllable yet keeps top speeds available if necessary.
The Speed Control limits top speed and spreads the desired speed over the full movement of the joystick.
The Deadspot control determines the center band of the joystick where no motion will occur. This way you can set it to your abilitites and insure no crossover to the other axis when not wanted.
The controller may be used in the handheld position, from a flat surface such as a tabletop, or attached to the boom arm of Jib.
Includes:
- Pant/Tilt Head
- Joystick Control Unit
- 20 Foot Long Control Cable
- XLR-To-Cigarette Plug Adapter Cable (for using 12/24VDC Battery Packs)
- Camera Mounting Screw (1/4-20)
- 4 Head Mounting Screws
- Allen Wrench
- AC Adapter
- Carrying Case With Custom-Fit Packing
- Instruction Manual
Specifications:
- Maximum camera weight: 19 lbs.
- Pan movement: 360 degrees
- Tilt movement: 360 degrees
- Variable-controlled speed from 6 degrees/sec (low speed) to 51 degrees/sec (high speed)
- Minimum height of head: 18"
- Maximum height of head: 26"
- Precision machined parts with the highest standards of industrial grade electronic components
SOLD!! ---- SOLD!! ---- SOLD!! ---- SOLD!! Asking $670.00 O.B.O. + $20.00 shipping in CONUS
Note: Camera and crane pictured are not included.
I can be reached at 206.706.0176 Mon-Fri from 7:00am to 2:00pm PST, or at kagrohs -at- comcast -dot- net
-Ken
http://www.omegastudios.net/temp/proaim_head-0.jpg
http://www.omegastudios.net/temp/proaim_head-1.jpg
http://www.omegastudios.net/temp/proaim_head-2.jpg
http://www.omegastudios.net/temp/proaim_head-3.jpg
http://www.omegastudios.net/temp/proaim_head-4.jpg
http://www.omegastudios.net/temp/proaim_head-5.jpg
http://www.omegastudios.net/temp/proaim_head-6.jpg
http://www.omegastudios.net/temp/proaim_head-7.jpg
http://www.omegastudios.net/temp/proaim_head-8.jpg
http://www.omegastudios.net/temp/proaim_head-10.jpg
http://www.omegastudios.net/temp/proaim_head-11.jpg
http://www.omegastudios.net/temp/proaim_head-12.jpg
