Francois Zaidi
Hello
I shot a short using 7Q+ in RAW with FS7, that was also recording xavcI for proxy.
The short is editing, and I exported an XML to resolve.
When I'm linking the xavc clips to the dng ones, some clips (quite a lot), are actually not exactly synched. The RAW files is one frame earlier.
I checked into one NLE, and it is the same.
It is consistent with a 1 frame delay between the SDI trigger of the FS7 to the 7Q.
Has anybody encountered the same issue ? Is there a fix ? Or do I have to spot them and... change it by hand in resolve :crybaby:...
The odd thing is it is not concerning all clips, just most of them...
Thank you !
Edit : I found 1 more issue.
1 clip (only 1 clip) on the 7Q has the last 500 pictures black. The proxy does not. The sound, however, is stil there, so I do not think it might have been a cable signal lost !
I did not see that while shooting. Of course, I needed the shot...
Thank you !
