FS700's Preamps vs H4n/H6/others?
Hi folks!
I was wondering how the FS700's internal audio preamps compare to the common affordable Audio recorders? I watched some reviews on youtube about the H4n vs the H6, stating that the H6 has better preamps which results in less noise when in usage with a Rode NTG2. To improve my Audio Quality i'm considering to get myself an H6 or something similar if you have any suggestions!
Do you think an external Audio Recorder makes sense, or should i dump that idea and get a pack of wireless Lavs? Really looking to get the most out of my NTG2 though...
Thoughts?
Cheers!
What kind of stuff do you normally do? How many people with audio at once. I've done small stuff all the way up to conferences/shows with 32 input mixers and you are always picking and chosing and adjusting. So let us know and we can guide you down a path.
I will say that the preamps on the FS700 really seem fine to me for most uses. At the point where I'd question the quality/usefulness of those I'm actually beyond it because I've hired a dedicated sound guy with his own gear. And usually it is recorded internally to the mixer/recorder as well as on board to the camera and they give me both.
Thanks slipstrea! Usually i'm shooting interviews with one person, corporate promos and such.
Is there anything in the 700's audio menu that i should adjust according to the shooting scenario? Any tips?
Of course, on a bigger job i would hire a Sound guy - sometimes a relativeley small, portable recorder comes in handy though.
A typical shooting scenario would also be shooting HFR, happy and laughing people interacting and talking with each other, where the recorded sound could come in handy.
thanks!
The FS700 has pretty good preamps and audio. My Sound Devices gear sounds better however getting a better mic would be the first step (or lavs if that makes sense for your needs (not as high quality vs good shotguns/supercardioids but can sound better if you don't have someone to hold a boom pole close to the speakers. Oscar Sound Tech makes affordable upgraded lavs for the Sennheiser G3)). We have an NTG2 and it's a decent mic (sounds best on phantom power). If you're looking for the 'Hollywood' sound the NTG3 or MKH416 are popular. I find the AT BP4029 mid-side stereo shotgun to sound excellent and is versatile. Tons of info over on gearslutz.com.
Honestly for interviews I set up a boom pole on a mic stand or a C-stand. No issues with hiding a mic and clothes rustling. And it will sound just as good. I do voiceover work on the side and I use an Audiotechnica 8014B. It works pretty good. And for an actual shotgun microphone my next upgrade will be the Sennheiser MKH416. It is the gold standard of shotgun mics. There are better ones but they cost LOTS. The 416 is only $1000 for great audio.
Lightstand plus boompole is what i do. It works, maybe the reflective buildings i am working in mostly screw up the sound more than my setup. Any hints on this? Reflective floor - boming from above or below? Bringing a carpet to take away some reflections?
Thanks for all the suggestions! Would love to hear opinions about recorders too if possible!
I get the mic as close physically and how it is pointed to in front of a person's mouth as I can.
For voiceover when there is obviously no need to worry about the video of a mic in my face I go about 7 inches from my mouth. Yes that close. And then I hold it off to the side to reduce pops and breath noises (wind from my mouth).
So you won't get a mic that close really ever. 2' I'd say at best so you can point it pretty close to in front of their mouth. Then just work with the room best you can. I don't point the mic at the floor ever really I try to point it at chests if I am running around doing a boom. Interviews at a mouth because they nor the mic really will be moving.
http://www.avisoft.com/recordertests.htm
Recommended: Sound Devices 7xx, Fostex FR-2LE, Tascam DR680, Roland R44 (not listed above). Sony has great recorders, but no XLR inputs (some have adapters- more complexity).
We have a Zoom H4n (too noisy) and a Tascam DR100mkII (has a digital input for recording the digital output from a Sound Devices USBPre2). The DR100mkII is too noisy when used in analog mode (but good enough perhaps for some uses- e.g. loud environments); when used in digital mode, recording the SD digital output, it's just as good as an SD 7xx recorder (same mic pres and electronics). In the end, we use the USBPre2 as a standalone preamp in the studio (using a USB power supply) and in-camera audio in the field (the extra complexity of a separate recorder for run & gun wasn't worth it).
The Zoom H6 has gotten good feedback on gearslutz: http://www.gearslutz.com/board/remo...ng/899767-best-preamps-portable-recorder.html, however reports of noisy preamps here: http://www.bhphotovideo.com/c/product/967366-REG/zoom_h6_handy_audio_recorder.html
Tascam DR60D reported as quieter, however noise artifacts reported: http://www.bhphotovideo.com/c/product/929347-REG/tascam_dr_60d_4_ch_track_linear_pcm.html
A Sound Devices Mixpre-D might work well into the FS700 (fantastic preamps and limiter), but again a better mic (something on the level of the MKH416 or better) would probably be the most bang for the buck. For standalone recorders, the ones listed a the top of the post are the most popular for pros. If you want to spend more money there's these:
Nagra V - http://www.nagraaudio.com/pro/index.php
Zaxcom Deva - http://www.zaxcom.com/
Aaton Cantar - http://www.aaton.com/content/overview
Sonosax MiniR82 - http://www.sonosax.ch/recorders/minir82/minir82_index.html
(from: http://www.gearslutz.com/board/remo...anything-better-than-sound-devices-722-a.html)
the H4n and the NTG-2 is an awful combination. The H4n Pre-Amps are real crap and produce a hell of noise but in combination with the NTG-2 it's fatal.
I had the NTG-2 and the H4n and I sold both. I tried to work with a boom to capture sound for a testimonial statement with this combination and I was really dissapointed. In one meter distance (max 1.5) and I had to push recording levels nearly up to max and the result was still low. I could save this take by pushing the levels in Audition and cover the upcoming noise with overlay of atmosphere sound.
After some reasearch I found out I was not alone. Forums in the past 2 yrs only are full of complaints about this combination. H4n seems to have a cheap PreAmp and NTG-2 low recording level (15mV/Pa) too. For the price NTG-2 is a good-sounding mic but it is not sensitive and it needs to be very very close to the subject. H4n has good-sounding on-board mics but pre-amps are miserable for external mics.
I went for the Roland R-26 and a Sennheiser ME66/K6 (50 mV/Pa) and I am very happy with this combo and each of them too. Sennheiser costs more than twice but its way better than the RødeNTG-2 and worth the money. If you have phantom power and don't need battery power you could also go for the MXL FR-300 Price is quite the same or even cheaper as NTG-2 but I sound and sensitivity (45mV/Pa) is much better.
I cannot say anything about the H6 but even if it's improved since the H4n the NTG-2 has still the same "features". I did not understand why it became so popular, maybe because of some well known blogging "cinematographers"
So many good suggestions! I'm considering getting a different mic. The mkh416 would be great, but to pricey for me. The me66 looks attractive though, thanks clermond. Does anyone else have experience with it?
cheers!
My rental house has a few shotgun mics. Most popular are the ME-66 and the 416. People like the ME-66's more than the 416's for some reason. $5 rental price difference? I dunno. Pro sound guys or the guys who know what they are doing go with the 416. But I wont knock the ME-66. The onboard power source of a single AA is nice if you do not have +48. Or if your outboard recorder is drained by the phantom power quickly (Zoom H4N).
All in all it is a nice choice. I'd reccomend it if you don't want to or can't get the 416.
I've been using the sennheiser wireless lavs almost exclusively, and they work fine for interviews. Just minor EQ in post.
When not doing interviews, the absolute best mic i've used so far is an audio technica. The model escapes me at the moment, but it beat the rode NTG right out of the water. I also use it with the XLR transmitter to have wireless sound. To me, sounds great with no issues.
i decided to put my NTG2 up for sale. I can get a good deal on a used ME66 if everything works out. I'll test the Mic and decide if i still need an external recorder then...
sounds like a plan - but sooner or later you should go for a recorder because of several reasons. There a a lot of situations when you cannot plug your boom mic into the camera: camera is moving, person is moving, camera is too far away.. Also it's good to have the in camera recording as backup of for ambience sound. Boom operating is no rocket science, one of your buddies can learn that quite quick and you won't have to hire a sound guy for interviews, testimonials, shorts.. You can charge for sound but don't have to spend much ;-)
true that! will definiteley get a recorder sooner or later.
