FS700R with 18-200PZ and 18-105PZ and 4K?
firehawk
How well does the Sony 18-200PZ and 18-105PZ do when recording 4K?
4K will obviously mean higher resolution demands of the lens and use of an external recorder which will bypass software lens correction.
I'm talking specifically these two lenses in case the above isn't clear since their are so many lenses :
Sony E PZ 18-200mm f/3.5-6.3 OSS Lens
Sony E PZ 18-105mm f/4 G OSS Lens
Thank you :)
I am using the Sony E PowerZoom 18-200mm f/3.5-6.3 OSS Lens with my 4K FS700. Its working fine. The lense is sharp and I cant see any issues with the resolution and 4K. Sure its only 6.3, but under good light conditions its more than ok
Benn
I believe the 18-105 suffers from pin cushion distortion that needs to be corrected. There was a firmware update for that to happen in camera, but it won't work when outputting RAW (ie 4K).
