FS700 & Odyssey 7Q – Dubai Marina in 4K and lens resolution tests
llirik
Hey everyone,
Been following for a while and seen plenty of little test on the fs700+7q front, but none have covered actual lens choice and how they resolve in 4K. So i decided to test it out while also getting comfortable with the whole setup. Obviously, this is limited only to the glass that I have, but it gives you good idea of how the lenses render with a Speedbooster. IE, i knew the canon 50 1.4 would be soft... but not THIS soft and unusable. I also found the kit lens 18-200 to be quite good on the wide lens, then not ideal on the long side.
Anyhow, you can read up on it here, or just view the videos below.
http://www.llirik.com/2014/04/fs700-odyssey-7q-4k-lens-tests/
And this is a similar video, but in HD with 100% scale for reference.
