FS700 not generating continuous timecode
ebsseattle
For the past couple weeks, my FS700 has been recording footage and always having each clip begin at a 00:00:00:00 timecode. In the past, when ingesting to FCP7, it would show me a different "Media Start" timecode for each clip. But the way it's loading now, FCP sees each clip as duplicates of previous clips.
Is there a setting on the FS700 that I need to change to get continuous timecode?
Timecode needs to be in Free Run. Get used to checking this menu often if you want timecode to keep working.
Anytime you go to high speed it will set back to rec run. VERY VERY annoying bug of FS700.
Anytime you pull a battery out to quickly (i.e. don't wait for the red blinking light to stop) the timecode will set back to rec run also.
