FS700 Mic mount tore out - broke
firehawk
Well, opened my case today and saw my factory Sony mic drooping down onto the lens.
Where the factory shotgun mic holder mount is joined to the cold shoe piece is just rubber and it has come out. Looking at this I can't believe it was made so flimsy! Almost nothing holding it in!
Since I typically leave the mic on the camera I either need to replace or repair it. Since it's rubber fitting inside plastic I guess I'll try some glue.
What's you guys experience with this?
I have replaced that once - however as a spare i did glue the broken one. If I recall that part from Sony was 100.00 - a bit much. If brakes again I will just glue it
Thank you. I looked inside and there's almost nothing holding it together. There are two little screws which barely even make contact, much less penetrate and provide holding power. And the thin contact area of rubber. I'm surprised it lasted as long as it did (a few months).
I figured the part was expensive.
It might be worth checking out 3rd party options from the likes of Rode or Sennheiser - just check that the shorter Sony mic will fit in those mounts.
