FS700 Handle extensions and Power options now in stock at WestsideAV
olof
DVXuser Sponsor
We now have the handles and the power plugs for the FS700in stock.
Photos are of my 700 with my shoulder rig and optional 15mm rods.
The back plate for the IDX battery will also hold a NanoFlash or similar device.
The photos also show the new version of my EVF bracket, not using the shoe type mount, this is much sturdier, I have another version as well for the Small HD DP4, it is a little to heavy and really need to use 2 attach points on the EVF to be absolutely stable.
The EVF brackets and the whole shoulder system should be back from the anodizer late next week. I will post more here as soon as production versions are available.
If you are in a real rush I do have un anodized versions in stock. Contact me directly to discuss options.
Olof@westsideav.com 603.383.9283.
The Handle Extensions can be ordered here:
http://www.westsideavstore.com/index.php?p=product&id=62
The Power Options can be ordered here:
http://www.westsideavstore.com/index.php?p=product&id=63
The handle in forward position
The handle in the back position
Closeup of 4 rosette version w/o handle attached
By moving the extension to the back it makes the handle position very nice for controlling the camera from the back on sticks.
The kit as shipped with either easy to adjust thumbscrew or low profile allen head screw.
The IDX solution for power, we supply the IDX plate and cable, or cable only (this is if you have your own IDX plate with 7.3v D-tap)
We also have an AB solution. But this only comes complete as the cable is direct out of the AB plate.
Does anyone know if there's a difference in the handle mount between the FS100 and the 700? Would love to get one for my FS100...
This is great, thanks!
My biggest complaint about doing hand held with this camera is that there is no place on the left side of the camera to balance or hold it. I kept hitting buttons every time I tried to steady it... Would be nice to have a solution for this... Maybe a a modified flash bracket or something.
