We have shot a ton with our FS700 but not alot of green screen. Here are a couple frame grabs of a test shot that we had done. It (example 1) was recorded externally via SDI to a Samurai (ProRes422HQ), however there seems to be a white edge (right side of neck and sleeve especially) around alot of the talent which is wreaking havoc on the final key. The white edge is present on the AVCHD footage recorded to the SD card, as well.
After simply selecting the screen color in keylight (example #2), now not only is the grayish edge visible, but the edges are extremely jaggy. Almost looks interlaced. It looks worse to me than keying SD DV footage.
There has to be a setting that I am missing here on the output of the 700. My rec settings are 1080P30 FX and the SDI is set to output 1080P. I know it's still only 8 bit output but this is just hideous. I've shot and keyed plenty on 8 bit 4:2:0 cams, even DSLR and it looked ALOT better. Anybody have any insight? I'd appreciate your input. Thanks!
