FS700 DIT Needs
The DIT on the shoot I'm working on tomorrow, wanted to know if the FS700 has any special needs, since he's never worked with it. I'm sure he's researching this as we speak, but can anyone here tell me?
What is the best way to watch the footage? I'm worried that it's going to be like the C300 and need a program to check footage and we won't have it.
Driver? Playback program? Things of that nature.
Thanks in advance.
-ryan
If you are on a Mac, as I am, things are a bit of a pain in the butt. Quicktime (unless you are on the latest brand new OS X Mountain Lion) does not recognize AVCHD.
So if you are Pre-Mountain Lion and on a mac, you need a program like Clip Wrap to convert the MTS files to quicktime to preview them quickly. Fortunately, Clip Wrap does converts the clips very quickly.
Usually I just make 2 folders, one that holds the .MTS labeled "MTS" and the other for the Clip Wrap converted quicktimes simply labeled "Quicktimes." Always keep the original .MTS files, as Premier works better with .MTS than the converted quicktimes which become H264 clips, but for some reason, the converted clips often crash Premier and run a lot slower in them, so they are for preview purposes only, and I just work with the .MTS files
The problem with VLC is it's pretty clunky feeling, at least to me. I guess I'm just not used to the Playlist interface thing that it uses. I find it a bit more Mac like just to use Clip Wrap and convert the .MTS into quicktimes, and watch the quicktimes how I normally would. But I guess that just what I am used to, and everyone is different and has their owns ways :)
I just take multiple cards and my macbook with FCPX. While I move on to the next card I can quickly preview the AVCHD clips in FCPX and then set it to transcode into prores 422 onto an external hard drive straight away. Works well for me.
I just import into a new Archive in FCPX w/o transcoding (optimizing). This is very fast, it does not take up more space and the content can be viewed from FCPX, or QT player (by right-click on Archive and then choose show content of package). I like the Archive packages they are very fast to back up and move around and content can easily be added to new Events. Or opened in any other QT based program.
If you have a fast Mac there is no downside to using the H.264 files for editing, final exported projects can be any codec you like with no loss. If you have a slower Mac then using proxy to edit is faster.
I use ClipWrap to rewrap if someone gives me MTS files only.
we edit with Avid MC and Lightworks, both on PC's.. our drill goes like this;
- card out of camera -> back up on seperate drives, once into a folder called; camera orignal/Day x/Card x and on the other drive a folder called Edit/Day x/Card x
- use clip wrap to re-wrap into h.264, onto the same two drives
- use file re-namer to prepend edit folder's files with day & card so the file looks like this when it goes into editing; D4_C3_000087.mov for shoot day 4, card 3, clip 87.
I have both Lwks and MC on my laptop running under bootcamp & a matrox I/O box + Sony LMD240W in a roadcase for the DiT's use if they don't bring their own (usulay they do bring their own mon, but not always as good/accurate as the Sony).
d
