FS700 Change Lenses and SDHC cards while Camera is ON?
Gene Sung
Just wondering if on the FS700, it's OK to change lenses and SDHC cards while the camera is ON?
I didn't see any No, No's against it in the manual. But I do remember Philip Bloom saying that on the Canon DSLRs it's better to turn the camera off while changing lenses because the sensor is exposed when the camera is on. Not sure if that applies to the FS cameras.
I usually turn the camera off while changing lenses or memory cards, but sometimes I forget and I don't want to harm the FS700.
I'd turn the camera off just to be safe....but that's just me and I don't like to take
any chances with my gear. That being said, I did change a lens once by accident on my
FS100 without powering it down and it worked fine. As for the FS700, the sensor would be
less exposed than the FS100 or a Canon DSLR because it actually has built in ND's.
Lens? No problem unless you're using a "smart" lens that is making contact with the electronic pins of the body. For the dumb lenses, look up "Lens Whacking".
Memory card? I'd never change one while the camera is powered up. I'd be afraid of data or directory corruption.
I always turn my camera off when I take my lenses off because the sensor will attract dust while its on. Also, with sd cards, ive never had a problem taking them out/putting back in while the camera is on, but its always good to be safe
