FS700 and F3 recording options wiht Odyssey7q / BM Shuttle
I'll shoot interviews for documentary with FS700 and F3.
I have Odyssey7q and BM Shuttle recorders.
What would be your advice for setup.
Odyssey 7Q:
Sony F3: Unc HD 10-Bit RGB 444 Recording (.dpx)
Sony FS700: 2K RAW 12-bit or 4K RAW to ProRes422 (HQ) 1080p S-log
BM Shuttle:
F3: 10bit color 422 (1.5 YCbCr?)
FS 700: 8 bit, S-logs: 4:2:2 uncompressed
Which with which you recomend to pair?
Which could be better solution for close up which for medium shot of?
The lowest posiible recording quality on the Odyssey7Q is the highest quality available on th​e Blackmagic Design Shuttle.
You are asking which to add to which camera while using both cams?
ODY - FS700
Ninj F3
then the are both 1080/422/10bit (or more)?
S
In this case, where your project is for documentary and/or interview purposes you might want to base your recorder choice more on the runtime and costs you will get based on each solution. I also know that BMD shuttle 2 can be fussy with SSD media and not sure you want to chance it without having really had a chance to time test it for yourself.
With the Odyssey it's also nice to have an extra monitor, but if you're run and gunning then you can use the built in LCD screens of the F3 / FS700.
If i record F3 in 10bit color 422 slog maybe its enough fs700 to record 4K2HD slog? Do I need 2K raw? final product is for cinema.
If you're going to 10-bit 422 ProRes with the F3, I would do 4KtoHD on the 7Q so both have 10-bit 422 ProRes files. 2K RAW is a bit overkill, IMO. File sizes are really big and I could be wrong, but I think CD's debayering of the 4K signal is cleaner than the 700's built-in 2K (line skipped, aliasing, etc). Others, feel free to chime in if I'm wrong about that. I don't shoot much 2K RAW on the FS700 except for 240fps mode, which has pretty significant aliasing compared to 4K and 4KtoHD ProRes.
