FS700 180 Degree Rule
NorBro
Major Contributor
When possible, should you follow this for slow motion as well? I.E - Shutter Speed 1/500 for 240fps?
Thank you.
Thank you.
Yes, if you want the motion blur to match other footage and looks presumably shot with an 180deg shutter. The shutter timing will match best if it all has an exposure period that's half the frame length. Then again for low motion, shutter speeds and blur lengths are less discernible, and a lot of things that would be high motion at 24fps are quite low ,otion in 240fps, so you maybe be able to get away with a bit more in some cases.
