paulcurtis
has there been any pricing info on the interface unit?
i saw that the recorder will need the big battery block on the back, is that a v-mount battery? does anyone know if the aux port (BNC) on the AXS-R5 Recorder is usable for monitoring?
EDIT:
HD output for monitoring
HDMI/Component/Composite video outputs on NEX-FS700 and the AUX OUT of the AXS-R5 can be used for monitoring purposes.
The battery is the 'Olivine' type which has higher capacity. It is down as being V mount though, i i must assume the back of the AXS is vmount. Whether the power draw of the recorder requires 'Olivine' or not, i don't know. I would guess not.
However it's the cost of the media which gets me. A single card is very expensive. You'd probably need two. Plus i think you have to have the dock in order to read the data off (USB 3) unless you can connect to the recorder directly? I think the media costs alone would be the same price as the Odessey...
cheers
paul
