I am borrowing a friend's Ronin and was just out shooting some tests... I'm a bit frustrated by what I assume is a bug (one that could potentially ruin footage). So I was recording 4K24 with a LUT on the Viewfinder only (pic 1), recording Slog3. I switched to S&Q 1080p for 180fps, still rolling Slog3 (pic 2). Then I switched back to 4K24, the only change I made in the menu was Rec Format changing from 1080p to UHD. And Pic 3 is what was captured to the card. Keep in mind that I'm in CineEI mode, and LUT was "OFF" for all options except Viewfinder. Footage is really ugly and contrasty, highlights blown out and completely unrecoverable. I'm perplexed as to how it happened and I'm really glad it didn't happen on a shoot.
We went into playback and noticed that those clips were super contrasty compared to the Slog3 shots. I jumped back into camera mode and the Viewfinder said "Slog3" (not LC709A, which was the LUT I had enabled for the Viewfinder), which indicates that it SHOULD have been recording Slog3. And when I put it into Catalyst browse, the metadata still sees it as Slog3, because I get temperature and tint sliders, which don't show up when you burn-in a LUT. I'm really confused.
