Has anyone with FS7 and either of these Metabones adapters updated both the FS-7 to the 1.01 firmware as well as updated the Metabones with the software updates just posted?
If so, I would be curious whether it has improved performance of the Metabones products.
Ned Soltz
I have to say that I have the slow reaction of the Iris here
but the flashing only appears when you're in "green mode"
of the adapter.
I have the Mark II Smart adapter and the old Speedbooster.
All lenses I tested work without flashing Iris, but are cumbersome
to open/close because it's so slow.
Please be aware that the Metabones adapters have 2 modes!
Green mode isn't meant for video whereas advanced mode
is the one to go with for me...
More info here: http://www.metabones.com/article/of/green-power-save-mode
Problem is the Metabones doc does not specify which procedure is for which mode.
I have a rental EF to E Mk IV and no manual. Anbody know of a better doc or something that tells me which button is which? Is the round button the DOF preview on the adapter?
Metabones seriously needs to have better info online.
Thanks,
Robert
I have never had the "iris flashing" issue.
Just switch over to advanced mode...
There's still the issue of the iris dial on the camera being not responsive enough.
I don't think this will be solved with a firmware update of the adapter only.
My Sony SEL18-200 behaves very similar without any adapter.
Some lenses (i.e. Canon 17-55/2,8) don't have a problem at all, most of the
lenses work but are quirky to operate via the iris dial.
Let's just wait for the next firmware of the FS7...
You can't do that with the old firmware of the MKIIs (which is 16 in most cases).
You need at least version 24 to make advanced mode standard.
FYI:
When I use my MKII, you don't need to shut the camera off and on again, if you forgot
to do it. You can just release the lens a little bit and lock it again whilst the button on the
adapter is being pushed. Sounds weird, but sometimes works better than shutting the
camera off and on again...
If you want firmware 24 or better, you need to send the adapter to Hong-Kong...
Guys, read the Metabones manual! http://www.metabones.com/article/of/green-power-save-mode
There's only 1 button on every adapter.
It's the above described "full open" button...
<Stuff Removed>
I am rapidly concluding that short of a manual adapter like the one for Nikons there is NO system that is going to offer smooth, incremental iris changes on EF or Sony glass that are to my satisfaction.
<Stuff Removed>
I am rapidly concluding that short of a manual adapter like the one for Nikons there is NO system that is going to offer smooth, incremental iris changes on EF or Sony glass that are to my satisfaction. It appears that electronic iris control will always be steppy and lacking a feathery ability. I am even doubting that the iris control ring on the FE 28-135 will be perfectly smooth. ( j/k)
