seanmc
So if the decrease in DR for high speed RAW recording with an external recorder is a data rate limitation of the single 3G-SDI connection...as this update states...wouldn't this also be the case with the FS700?
"However, we also found that the bit depth is still lower at high frame rates (e.g.: 240fps RAW). This is due to the limited data rate that can be put through a single 3G-SDI cable. Thus dynamic range on internal recordings (XAVC) remains slightly higher."
http://nofilmschool.com/2016/01/sony-fs7-firmware-update-3-0
